10-20-2017, 07:59 PM
#31 (permalink)
Originally Posted by Panther140
The sizing of the engine has nothing to do with it. Regardless of which car you are in, drive like Ecky and I are saying. It is the most efficient way. Get the work done with the engine at peak torque and WOT. Coast down the other side. Avoid wind drag.
Peak torque on many small 4 (and 3) cylinders is above 4000rpm, but peak efficiency is usually below 3k. In the case of my Insight, it's 4800 peak torque, 1750 peak efficiency, with terrible BSFC at 4800rpm.
10-21-2017, 08:54 AM
#32 (permalink)
I did an 80 mile trip today, utilising Ecky and Pather's methods and I must say, I got good mpg. My 1.2 litre 4 pot Jazz develops maximum torque at just over 2500 rpm. so I used WOT to get there, then minimum MAP to keep it there.
Averaged 67.8 mpg (UK)/56.5 mpg (US).
10-21-2017, 11:44 AM
#33 (permalink)
Shown below is the calculated engine power requirement for a European spec Mitsubishi Mirage 1.0 for 2 different operating conditions.
1/ flat road, constant 80 km/hr
2/ 5% gradient hill, constant 80 km/hr
It is evident from the BMEP of 9.21 that this engine is almost at full throttle climbing the hill.
Shown below is the 2 bmep values added to a bsfc map obtained from a similar engine.
It is evident that the engine is operating in the island of maximum efficiency whilst climbing the hill at constant velocity.
It makes no sense to go to WOT and have the sfc driven down from 240 g/kWhr to 280 g/kWhr.
Hence the concept that all cars should accelerate up hills is flawed!
10-21-2017, 05:16 PM
#34 (permalink)
Wouldnt it be very cool if you had the bsfc chart and where you are on it displayed in the car?
The Following 4 Users Say Thank You to teoman For This Useful Post:
11-22-2017, 05:09 AM
#35 (permalink)
I'm surprised to see WOT being advocated here when I thought Ecomodder rule #1 was do not use WOT.
How do you guys justify/explain using the fuel enrichment mode of WOT in preference to the closed loop control of say 80%-90% WOT in this uphill situation?
Not wanting to sound confrontational, I have an open mind about this, as I have yet to nail the art of efficient uphill, and on some occasions I have been surprised when flooring it uphill that the overall fuel economy was not as bad as I feared, so there could be something in it!
11-22-2017, 09:10 AM
#36 (permalink)
In my Insight, my AFR meter shows no measurable fuel enrichment with high throttle percentages. Under most driving conditions (where I'm running 1500-2000RPM), "25% throttle" via pedal position is effectively the same as "wide open", because pressing it further doesn't provide any more torque and doesn't burn any more fuel. It's a manual transmission, so pressing the pedal further also doesn't tell a computer to shift.
Generally speaking, having the throttle "wide open" up a shallow hill (without downshifting) will just about maintain a constant speed. So, for me, WOT is maintaining a constant speed up a hill, and it's also keeping me at peak BSFC.
So, I suppose it's important to qualify what we mean when we say "WOT".
11-22-2017, 09:24 AM
#37 (permalink)
As you can see from the charts, ~80% load is a good rule of thumb for efficient hill climbing. WOT is less efficient either due to fuel enrichment (which is pretty rare these days on naturally aspirated engines), or due to less than ideal ignition timing.
The Following User Says Thank You to Daox For This Useful Post:
11-22-2017, 10:14 AM
#38 (permalink)
When I drove a delivery truck , with light traffic & the hope the " Law " was not around , I would gain as much speed as possible in order to help make it up the next hill . But that was a much different situation . And I was not paying for the fuel .
With a car & light traffic , I let off of the accelerator to the point where I think there is no engine braking . Then increase accelerator pressure to make it up the other side .
Excessive speed only adds additional wind resistance , consuming additional fuel .
Happy thanksgiving to you all , :-)
Wyr
God bless
11-22-2017, 03:34 PM
#39 (permalink)
In my truck I would do the same as wyr.. just enough throttle downhills so I can hear the whine of that light loading on the rear end gears. Out of boost, but negating any engine braking.
But I'm talking a box on 65-85mph highways. Air is the major factor for my driving of hills. You don't really want to be throttling hard downhill no matter the situation. Air resistance would eat up your fuel. I'm not sure what kinds of speeds the other posts are talking about, that would make a big difference.
99% bev now
1% other junk
11-23-2017, 06:38 AM
#40 (permalink)
My POV (nothing unique I suspect).
If we simplify to remove all other variations. I think that's the 1st (ideal) case (Peak Energy Efficiency BSFC up hill (which not always the same as WOT) , EOC down hill, same average speed/conditions,etc).
The YMMV comes in (I suspect) from when some of the other variables start changing as well. For example. - If to get the power to accelerate up hill you moved the engine/transmission into a less energy efficient condition. This is a negative reducing possible gains.
- The worse BSFC for the ICE is one part, and can be seen on a BSFC if you have such.
- Worse for transmission is not mapped as often as a ICE BSFC.
Although transmissions are usually very efficient (upper 90s %). All gears are usually not exactly equal in their throughput energy efficiency. Some will be a little bit more efficient than others. When the simple case of two gears being otherwise equally efficient, higher transmission RPMs are usually less energy efficient than lower transmission RPMs.- Also worth noting here, from 98% to 99% is a 1% difference in an absolute sense, but it is also double the losses (1% x2 = 2%). As such it might not always equal to a 1% difference in observed overall fuel efficiency.
- Any air speed variation is always less aerodynamically energy efficient than an equal average wind speed. This is due to the exponential nature of wind resistance, and does not apply to any types of linear resistance.
- For example:
Person A's speed is steady relative to the air.
Person B's speed varies relative to the air.
If both average the same overall speed, and if all else were equal.
The speed variations of person B would require more energy.. Thus less efficient.
This is a negative acting to reduce potential gains.
- Speed creep.
- Many (not all) people get desensitized to faster speeds. The slower speeds seem slower than they really are. This can lead to the person who is accelerating having a subconscious leaning toward less time at slower speeds. Increasing the overall net average speed. If than one averages a faster speed they will have more net wind resistance energy losses, and thus lower combined MPG.
- This also happens with some people with a positive psychological feedback to the psychic effects of acceleration itself. If they perceive the acceleration to be a positive thing, some people will then subconsciously do more of it. To people of that type the gravitation effect of going up hill adds to the feeling of road acceleration.
- For any newbie who might has asked:
Why not maintain peak BSFC energy efficiency on both up and down hill .. because then you'd be going much faster and have much higher wind resistance losses. The faster you go the more energy per mile you are spending. If ICE and transmission is already at peak energy efficiency, any speed faster than that is only a negative.- There would be a potential overall breaking even point if there is another hill to climb after the down hill. Exact break even point would vary. But, as such , under some conditions, staying at Peak Energy Efficiency ICE & Transmission might be a net overall benefit. Although the continued running of ICE on the down hill, will (almost always) be a negative for that one hill.
- Worth noting that higher fuel efficiency is possible at lower energy efficiency. If you go slower your energy losses/(required consumption) per mile go down. As long as those energy consumers go down faster than one's fuel to wheel energy efficiency you are getting higher Fuel Efficiency , even with lower Energy Efficiency.
- Changes in the air (Up-hill vs down-hill)
Uphill and down hill wind speeds are almost never the same. Nor is the air pressure. Nor is the air density. etc. One's wind resistance is not about vehicle to ground, but vehicle to air. - Although of course not true in all individual cases/conditions. I suspect overall for a large enough sample size. That statistically one side has higher wind speeds , higher air density, etc than the other side of the hill. I further suspect that (in a large enough sample size) it is the side that is up-hill from the POV of the wind that is most often the one with faster,denser air speeds.
- So, going faster up hill statistically most often faces a relative air benefit. Although likely to be tiny.
For Example:
Say The Wind is moving West to East.- Those going up-hill (driving west to east) have the wind at their backs and their relative air speed is lower, thus less wind resistance , thus less energy to travel the same speed. Both Uphill and down hill. But the Air itself as slowed a little and provides less help, thus more wind resistance on the down hill side.
- Same hill same wind direction. The air/wind (statically large enough sample size) has lost a tiny bit of density/pressure/speed as it climbed the hill, and now requires slightly less power/energy for the car against it driving up hill. Those heading East to west are driving into the wind (both uphill and down hill). Up hill face slightly less dense air that is slightly slower. While they will face slightly faster and slightly more dense air on the down hill.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
