05-06-2018, 03:43 PM
#691 (permalink)
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
Originally Posted by Bicycle Bob
A shape like that template was the inspiration for many early experiments in streamlined road-race cars. They got an evil reputation for tricky handling at high speed.
I imagine there must be a lot of lift involved especially in higher speeds.
The Following User Says Thank You to seifrob For This Useful Post:
05-06-2018, 05:50 PM
#692 (permalink)
I miss that guy.
I feel exactly the same.
I like to think he's a lurker.
My solution for downforce on Thee Template:
Superelliptic cross section and a truncation that incorporates a passively suctioning bellmouth. It might be beneficial for minimizing downforce ( vs usable interior volume) if the superellipse were rotated 45°, that would minimize the upward facing surface.
05-06-2018, 10:21 PM
#693 (permalink)
Originally Posted by California98Civic
Yes,horizontally, but horizontally as well as vertically? I'd like to see that one.
05-06-2018, 10:23 PM
#694 (permalink)
Yes, active wings would be needed at higher speeds, maybe even a rudder to fight side winds.
05-07-2018, 01:44 AM
#695 (permalink)
Adding anything is antithetical to the purpose. That's why it is a thought experiment that has no relation to the needs of a ground vehicle. Lighting, licensing, ingress/egress and sight lines all need to be accommodated.
More successful are the Morelli body and the spatted ellipsoids you see in solar and human powered vehicles.
And maybe the exponential b*tt trumpet I showed in Permalink #629.
05-07-2018, 07:52 AM
#696 (permalink)
Would it be more effective if your ground effects bellmouth began near the front axle, and your humans sat to either side of it? I assume (yes, I know) this would be a four wheeler, as a reverse trike layout would place a wheel in the bell mouth area, and disturb the effect.
05-07-2018, 10:45 AM
#697 (permalink)
Cyborg ECU
Whenever I think about highspeed stability of the template I think of the HASPORT first Gen Insight crash at El Mirage in 2013... that was about 200 mph. An active wing for super high speeds might have prevented the incident, I imagine.
05-07-2018, 11:17 AM
#698 (permalink)
Aero Wannabe
Originally Posted by Angel And The Wolf
Has anyone built a full sized two passenger or more version of this shape, and driven it?
Yes, Buckminster Fuller and his Dymaxion.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
05-07-2018, 01:45 PM
#699 (permalink)
Dymaxion was a full body of revolution with it's nose up in the air.
His intent was that the tail wheel would lift at speed and it would mimic a tail-dragger airplane between taxiing and rotation.
Closer would be the Schlorwagen
http://www.curbsideclassic.com/automotive-histories/automotive-history-an-illustrated-history-of-automotive-aerodynamics-part-1-1899-1939/
Even it softens the hard chine at the lower edge.
If there were zero air intruding under the Template, would it experience lift, or would it be burrowing under the air like a mole (or vole) in you yard?
05-07-2018, 01:58 PM
#700 (permalink)
Mr. Beard, how does the bloated noodle work with a reverse trike?
