Old 02-15-2018, 09:34 PM   #1 (permalink)
Another Radical Idea
Forget this design. I've superseded it with a trailer. (See permalink #13)
Name:	2011 prius 2.8 with wheel.jpg
Old 02-15-2018, 10:00 PM   #2 (permalink)
Of course that can be done provided it's built stout enough. Not sure I'd want to drive around with that heavy a tail unless it provided another use like good strong cargo carrying capacity that would actually get used.
Old 02-16-2018, 01:51 AM   #3 (permalink)
These radical ideas all follow a theme.
Compare to a higher tail that gets you the departure angle you want, and has a flying wheel that only has contact before the boat tail proper ground-strikes. Since it doesn't have to carry the weight for three wheels, it could be lighter.
"We're deeply sorry." -- Pfizer
Old 02-16-2018, 05:09 AM   #4 (permalink)
Edited. See Permalink #13
The Following User Says Thank You to Angel And The Wolf For This Useful Post:
freebeard (02-16-2018)
Old 02-16-2018, 03:06 PM   #5 (permalink)
Dark Egg - '12 VW Touraeg
What would be really radical would be to make it strong enough and always in contact with the ground carrying the rear weight. Then remove the entire rear suspension, smooth the openings and have a trike.
Old 02-16-2018, 03:19 PM   #6 (permalink)
There is a trade off between fuel saved by improved drag reduction and lost from the increased weight penalty. Decide how much cargo capacity and access you need in the rear. Consider a tub structure rather than a beam support.
Old 02-16-2018, 07:00 PM   #7 (permalink)
See my new design for the linkage at Permalink #13
Old 02-16-2018, 07:28 PM   #8 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
What is the advantage of the wheel? When it isn't touching the ground, it's placing extra stress on the frame, and when it is hitting the ground, it's due to lack of clearance, which places a great deal of stress on the frame.
Commercial airlines don't use tail wheels, but instead leave sufficient clearance to maneuver.
I'd say go with the KISS principle.
EDIT: Nevermind, I get the purpose. Design the most aero efficient angle on the tail and mitigate the issue of tail strikes.
What about placing the tail on a spring loaded hinge so that a friction surface on the bottom of it strikes the ground and moves the whole thing up, and then returns to position once clearance is no longer an issue? Better to move the smaller, lighter object than to make the whole vehicle conform to it, right?
Old 02-16-2018, 07:45 PM   #9 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Trailer hitches are designed for down loads of around 200lbs. This design would be a good way to bend chassis rails or rip the attachment points clean out of the chassis.
The Following User Says Thank You to oldtamiyaphile For This Useful Post:
Old 02-16-2018, 08:10 PM   #10 (permalink)
OK, I'm going back to the one wheel U-joint stabilized trailer. Forget the drawing below. See Permalink #13
Name:	2011 prius 2.8 trailer-tail.jpg
