09-02-2015, 05:50 PM
#11 (permalink)
I'm taking this semi-seriously. The biggest intellectual hurdle is figuring out where I would park the thing.
I want to put a hitch on my car and restore the Westy trailer anyway, and it has a steel frame supporting a plywood box. The tongue and axle bolt together and there is a 2x2" wooden joist supporting the back of the box. Deleting the box would make it a dolly. The tongue is 3' and the axle is 53" to the outside of the trailing arms. The wheels are 16x5".
Your wheels are smaller, and you plan on four, right? I was thinking of a towable model but to match your dimensions it would have to be trailerable.
My thought experiment is hang a flag on a long pole off the back of a short trailer. When the tow vehicle turns the trailer will follow, but the flag will be tangent to the curve and outside it. The steps would be: - Add a trailer hitch (and take the chatter out of the clutch)
- Restore the Westy trailer frame (new elastomeric snubbers and bearings)
- An asymmetrical pyramid made out of angle iron from Hollywood bed frames
- A two frequency geodesic made of luan plywood and aluminum taped edges
- Over that—a removable thin 4v shell
- Bonus: finally a sock over that that could inflate to a compound curve.
If the front wheels were in blisters a 4x10ft model would be half-scale. A Vespa front fork would be a good match for the Westphalia wheel size.
09-02-2015, 06:57 PM
#12 (permalink)
parking
Any Wal Mart will allow overnight 'camping' in their parking lots.
The larger LOVEs truck/car stations allow overnight stays.(if you park near the 18-wheelers,their engine noise drowns out distracting noises)
09-02-2015, 08:15 PM
#13 (permalink)
Hold on. I need to start with a trailer hitch.
....or maybe do 1/3 scale and put it on a roof rack.
09-03-2015, 11:49 AM
#14 (permalink)
How about lopping some of the tail off the template to simulate what is most often done with tails in the real world? Or is that well enough established?
09-03-2015, 12:56 PM
#15 (permalink)
The question to be answered by my following aerohead's dimensions would be the difference between a pointed tail like The Template and a rounded tail like the Dymaxion.
Truncations are do-able. Or one could add a strap-on cone, while [re-]considering the fineness ratio.
The larger question is the effect of creases in the surface. A 3v sphere has a break angle of 360/20 or 18°. A prolated sphere will be sharper at the ends and smoother in the middle, with the limit case being a compound curve. I want to see if there's any 'dimple' effect with the lower frequency. A 2v would be about as angular as the F-117.
09-05-2015, 12:39 PM
#16 (permalink)
lopping off
I want to verify the shape exactly as drawn.If I can fit it into the schedule,I'll do removable tail sections,but that doubles the difficulty in fabrication at this scale of build.
09-05-2015, 12:44 PM
#17 (permalink)
truncations
I've been struggling with an English translation of Kamm's research and what I can say is, 'don't do 'rounded' truncations.Make the cut as if you'd do it with a bread knife.Straight chop.
09-05-2015, 02:03 PM
#18 (permalink)
One of the forum members once tried a rounded trailer rear - it made it rather unstable.
You get Coanda effect as air flows over the rounded surface, pulling at the surface trying to lift it.
As the air flow is never even L/R it pulls more on one end, then on the other ...
The Following User Says Thank You to euromodder For This Useful Post:
09-06-2015, 10:39 AM
#19 (permalink)
Make the model full length and then cut a 20% truncation and tape it back together.
09-06-2015, 12:44 PM
#20 (permalink)
Double bulkheads at the point of the slice, for strength.
