Old 09-04-2012, 09:08 PM   #21 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
My 1968 AMC Javelin SST got 10 mpg with the 343 v8 and a crane fireball cam.
- Tony
Old 09-04-2012, 09:09 PM   #22 (permalink)
If you're happy with sub-20mpg then you can put just about anything in there. It's small and light enough for a 4 banger to move quite well. There was a guy on here that put a turbo 2.3 Ford in his Edsel.
Old 09-04-2012, 09:49 PM   #23 (permalink)
I personally would stick with anything fuel injected for the daily drivability and the prupose of having the best of both worlds in economy and a little power when you wanna romp on it.. And I personally wouldn't be scared of anything V8.
Corvettes have been known to stay in the 26-30mpg hwy with a 6spd and LSx engine... I like where this is going alot and kudos for finding such a clean car!
Old 09-04-2012, 10:55 PM   #24 (permalink)
Nothing wrong with keeping it all AMC and original. The T5 is the best card up your sleeve for FE, if you know what you are doing with the carb and distributor that car will get good MPG, those cars got good MPG back in the day afterall.
Old 09-17-2012, 03:33 PM   #25 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
i might be putting the 5speed swap on the back burner for right now. i ran into a 1971 258 that will bolt into this car and allow me to use the factory trans/bellhousing so i might go that route. it still should get low 20s with that setup and if something goes boom boom in the transmission ill have the other setup ready to go. it will be an increase from the factory 199 to the 258 so the increase in power is also a plus
Old 09-17-2012, 03:39 PM   #26 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Good luck. keep us updated!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 09-17-2012, 03:43 PM   #27 (permalink)
i will thanks!! i also purchased all of the brake parts for it. ill take some more pics and post them up. this saturday i might get over to the car and grab some more pics of it for before and after shots.
Old 09-17-2012, 04:55 PM   #28 (permalink)
Old 09-18-2012, 09:41 AM   #29 (permalink)
The first car I ever worked on was a 1969 Rambler Classic, 2 door, same blue, same seats. It was family transportation for us, my mom didn't have much money, so when the Rambler wasn't running, my brother and I would take turns riding out bikes to the store for groceries. With that motivation, at 14 years old, I figured out how to do simple things like replace the water pump, the starter motor, radiator hoses, with little else but some open end wrenches, dime store pliers, borrowed tools, and some automotive advise from neighbors (some good, some not-so-good).
Good luck with your project. I had trouble finding the right parts when mom's Rambler was only 8 years old. It seems AMC was at the end of the supply chain for assembly parts. They got the pick of whatever GM, Ford, then Chrysler didn't use. Midyear changes, several different part numbers to choose from, were all part of the process when working on AMC's.
Old 09-18-2012, 11:33 AM   #30 (permalink)
I found this in a field a few months ago...Never thought I would post here with it .. 1969 6cly three speed under dash air Strange my seat are still good also.
ID:	11516   Click image for larger version
ID:	11517   Click image for larger version
