12-03-2013, 09:22 AM
#41 (permalink)
Just in case you missed it, here's a link to Craig Vetter's page with some info from Tom Finch, Aeronautical Engineer, about the shape of the tail on Terry Hershner's electric Zero .
2013 Vetter Streamliner-Chap 68-redesigning Terry Hershner's-Zero
- About 3/4 of the way down the page
12-03-2013, 01:58 PM
#42 (permalink)
Originally Posted by euromodder
Are you going to fair in the rear wheel completely as well ?
If not, how about reducing the width of the lower part of the tail ?
It need not be any wider than the rear wheel (or swing arm) in that case.
You could also bring it closer to the far of the rear wheel.
Yes, there will be some sort of bodywork around the rear wheel. Good idea regarding reducing the width of the lower part of the tail. I will consider that in lieu of inclosing the rear wheel.
@JVK357 Thanks.
12-11-2013, 09:46 AM
#43 (permalink)
No work of late. Damn temperature has been around 15F average for the last week or so with snow on the ground and my garage is not heated.
Happy Holidays all.
Jeff
03-19-2014, 02:25 PM
#44 (permalink)
Hi everyone. Now that the weather has warmed up a bit, I will be back at it with my AeroNinja project. I will post up any progress soon.
One of the Craig Vetter Challenges will be August 29, 2014: Wendover to Ely, BUB Speed Week, Utah. I plan on being there (it is in my neighborhood)
http://www.craigvetter.com
Jeff
03-19-2014, 04:44 PM
#45 (permalink)
Jeff, Great to see you are back to work on your AeroNinja!
03-24-2014, 01:39 PM
#46 (permalink)
Hi JeffM,
May I suggest a diagonal brace between the frame tubes underneath the rear saddle and the middle bulkhead ?
In the bottom picture, it looks like it's made to have a brace there, by continuing the frame tubes.
If I may suggest, using thin aluminum sheet or the door skins as you said for the skin will more than stiffen up the tail. Notice that monocoque airplanes generally don't have diagonal bracing between the hoop frames. You still will need to have some sort of brace to just hold up the tail.
Also, the "strringers" seem a bit beefy to me. Adding excessive weight, especially at the rear, isn't a good thing.
-- Teri
P.S. Not to toot my own horn but when you add a full front fairing, you may want to read my thread starting at: http://ecomodder.com/forum/showthrea...tml#post416335 Pete [Ironside] has "proven" that a stall strip can radically reduce side wind effects on a dust bin fairing.
03-24-2014, 03:47 PM
#47 (permalink)
Originally Posted by Teri_TX
Hi JeffM,
-- Teri
Hi Teri. There is much more support structure holding the tail on including six individual tie-ins to the bike itself. In the photo the bottom part of the frame is missing. I am finalizing the bottom of the tail and most likely will reduce the depth in that area. I have some door skin ply to reenforce the sides of the cargo area.
I concur with you about the size of the stringers but I have already got to this point so I'll have to deal with some extra weight. It really is not as heavy as it looks. If I re-do the tail the next structure will be aluminum or fiberglass over pink foam monocoque.
I have been reading that thread and I am going to try to incorporate a stall strip on the tail. Craig Vetter suggested to me that they are worth trying out. I'm not sure what will be the result if I add a strip to the front wheel fairing. It may be worth a try.
Thanks for your input.
Jeff
04-07-2014, 04:06 PM
#48 (permalink)
Small update. I finally finished mounting the tail to the bike in a way that satisfies me in terms of safety and strength. Starting on the electrical.
Jeff
04-14-2014, 11:34 PM
#49 (permalink)
The Following User Says Thank You to JeffM For This Useful Post:
05-19-2014, 02:56 PM
#50 (permalink)
I have the tail off the bike now and have returned the bike to stock (nice to be able to ride again).
Currently I am painting the frame and deciding on final layout of cargo area, electrical, etc.
Ride safe.
Jeff
