08-06-2014, 01:59 PM
#181 (permalink)
I am going to ask if any one can tell me what difference between lower crank pulley and harmonic balancer pulley.? If I or someone replaces harmonic crank pulley with aluminum pulley how do you get it to be harmonic balance for a given engine. ??
08-06-2014, 10:04 PM
#182 (permalink)
Cyborg ECU
I am told the 1.5L civics did not have these balancers in the crank pulley. The 1.6L does. Something about harmonics, vibrations, and the size of the engine. But I am not well-informed on it. Sorry I'm not more helpful. Maybe someone else has a better answer.
08-06-2014, 11:05 PM
#183 (permalink)
Cyborg ECU
Bad engine mount, stuck tensioner bolt magic
Replaced the front engine mount (hadn't realized how bad it was):
Finally got the stuck timing belt tensioner bolt out, using the AWESOME Irvin "bolt-grip" socket I bought. Here is the bolt still stuck to the awesome socket:
The AWESOME socket in the "flesh"
08-07-2014, 08:48 AM
#184 (permalink)
Yeah, I have a few of those bolt extractors like that. They are a God send when you need them.
08-07-2014, 12:12 PM
#185 (permalink)
0.29 Cd and decreasing
I have a craftsman set of those and the last time I used it was on my 98 civic, the oil drain plug was probably put on with an impact gun and use couldn't get the bolt out! I ended up taking it to a shop and brought my oil and filter and they wouldn't use my stuff, like I expected.
08-11-2014, 10:01 PM
#186 (permalink)
JDM hypeR mileR
Great project! Love the "Extreme" poster on the first page.
The Following User Says Thank You to OG VX For This Useful Post:
08-21-2014, 07:12 AM
#187 (permalink)
subscribed
Always meant to read your thread, finally did and learned and enjoyed greatly. Subscribed. Thanks,
Benphyr.
The Following User Says Thank You to benphyr For This Useful Post:
08-21-2014, 09:55 AM
#188 (permalink)
fuel conserver
Civic - '99 Honda Civic EX
[QUOTE=Baltothewolf;438578]Hi Cacivic, what RPM do you see at 70mph with that CX tranny? I'm trying to find out what I will be running with the VX tranny I bought....QUOTE]
I did the calculations on 5th gear @ 70 before based on my EX speedo:
5th gen CX/VX: 70mph ~2,300rpm (3.25:1 Final Drive)
6th gen CX/HX/DX/LX: 70mph ~2,640rpm (3.722:1 Final Drive)
6th gen EX Coupe: 70mph ~3,000rpm (4.25:1 Final Drive)
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
The Following User Says Thank You to E.Roy For This Useful Post:
08-21-2014, 02:38 PM
#189 (permalink)
Cyborg ECU
[QUOTE=E.Roy;441474]
Cool. But one question and one correction: what were the wheel tire sizes? and the 6th Gen DX coupe and I think the LX too have a 4.058 final drive. The DX hatch had the 3.722 FD in the sixth gen, though.
Benphyr.
Thanks! I apprecitate the encouragement. I try to include success, failure, and the learning... for a log of what I do and also to help others. Thanks again.
08-21-2014, 02:55 PM
#190 (permalink)
fuel conserver
Yeah, thank you for starting a mod thread, good place to share info.
I got my final drive ratios off the internets, so....
My info says the 5th gen DX/LX have 4.058:1 and 6th gen 3door EX Hatch (? If they made one?) had the 4.058:1, while the 6th gen DX/LX have 3.722:1.
My tire size is stock 185/65-14
Formula for top speed:
Engine RPM x Tire DIAM (inch) ÷ Final Drive Ratio ÷ Trans Gear Ratio x 0.002975
For my '99 EX:
185/65-14 ~23.7"
FD: 4.25
5th gear .702
So 5th gear 3,000rpm = 70.9mph
Some manufacturers tachs read high, so they are not always accurate
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
