Register
Now
Connect with Facebook
Reply
Old 12-01-2008, 10:40 AM   #1 (permalink)
MR2 Turbo - '93 MR2 Turbo
90 day: 28.28 mpg (US)
Can I use 6-conductor RJ11 cord for Spiffie kit??
My spiffie.org MPGuino kit is on the way and should be here this week. I am having a hard time finding a nice black rj11 cord that is 4-conductor. Does anyone know if I can use a regular telephone cord that is 6-conducter because those are easier to find locally? If not does anyone know a good place to get a 4-conductor black rj11 cord? Thanks.
ERIK
Old 12-01-2008, 03:58 PM   #2 (permalink)
The Turkel - '93 Tercel base
90 day: 37.31 mpg (US)
It depends on whether your kit comes with a 4 pin connection, or a 6 pin connection. If it's a 4 pin, then a 6 pin wire might not physically fit in the socket. You might be able to trim off the ends on the wire to make it fit if that's the case though.
Old 12-01-2008, 04:45 PM   #3 (permalink)
The kit says it uses 4-conductor wire. But from my reasearch it seems like rj11 connectors are all the same. But the wire is different. So I was thinking that a 6-conductor might plug into the rj11 jack with the kit and just have 2 wires that arent being used.
ERIK
Old 12-01-2008, 05:21 PM   #4 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 37.75 mpg (US)
This might help : LINK
Old 12-01-2008, 05:57 PM   #5 (permalink)
Looks like you're absolutely correct. I didn't realize they were the same size physically. So yes, you can use a 6 conductor wire, you'll just have 2 wires that don't get used.
Reply
DIY - Front Camber Kit SVOboy DIY / How-to 1 12-05-2008 01:52 PM
Diesel electric kit car, anyone? R. Q. Riley's latest takes shape (and looks good!) MetroMPG EcoModding Central 11 10-07-2008 03:52 PM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 03:17 AM
electric bike kit - hub motor bennelson For Sale 6 05-19-2008 10:52 PM
Sterling Kit Car cfg83 Aerodynamics 12 01-16-2008 09:33 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
