Old 04-09-2013, 10:58 PM   #1 (permalink)
MPG...what?
Terkle - '97 Toyota Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '10 Toyota Yaris base
90 day: 41.88 mpg (US)
Deva - '13 Chevrolet Spark LS
90 day: 39.82 mpg (US)
Malibu5 - '82 Chevrolet Malibu Classic
90 day: 17.61 mpg (US)
Highlander - '06 Toyota Highlander Limited
Send a message via AIM to malibuguy
Chevy Spark + rear diffuser
Wifey's new ride gets its first "real mod"
GP Fabrications unit, very nice piece.
-Greg...the exhaust freak.
-06 Highlander 3.3awd
-10 Yaris sedan
-97 Tercel, 1NZfe swapped
-96 Tercel
-82 Malibu 1UZfe swapped
-19 Fit (wifey ride)
www.pipedreamsfab.com
Old 04-10-2013, 06:15 AM   #2 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
I'm jealous. I wish someone would make one of those for my Fit! I put a front undertray on, which helped mileage marginally (~1 MPG) but really, really, helped with stability at highway speeds and in windy conditions. But the back end is still open.
Old 04-10-2013, 06:44 AM   #3 (permalink)
MPG...what?
Its a universal piece. I had to fabricate/weld some aluminum brackets to mount the leading edge.
-10 Yaris sedan
-96 Tercel
Old 04-10-2013, 07:40 AM   #4 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
How did you gauge the angle? There are more and less effective angles, depending on vehicle. Can you adjust it?
Old 04-10-2013, 08:03 AM   #5 (permalink)
MPG...what?
I kinda just eyed it up. I put the leading edge just above what I think the main path of the airflow is going coming under the axle. I may have got it right. I may be off. I want to fill in the rest of the area once I get ahold of some aluminum sheet.
-10 Yaris sedan
-96 Tercel
Old 04-10-2013, 09:43 AM   #6 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Looks purty, but a diffuser needs clean flow to work properly. Since the underbody ahead of it is dirty, aerodynamically speaking, it's probably not doing much!
A belly pan would help. Next project??
aerohead (04-13-2013)
Old 04-10-2013, 11:25 AM   #7 (permalink)
MPG...what?
indeed. i want to look into maybe getting the factory panels from an EV Spark, but most likely Ill make my own. This car looks really simple to flatten out.
-10 Yaris sedan
-96 Tercel
The Following User Says Thank You to malibuguy For This Useful Post:
aerohead (08-05-2017)
Old 04-10-2013, 01:29 PM   #8 (permalink)
Question is, how it effects fuel economy. Looking cool can take a backseat.
Old 04-10-2013, 03:20 PM   #9 (permalink)
MPG...what?
The tank with it is the best so far...but we will see
-10 Yaris sedan
-96 Tercel
Old 07-29-2017, 04:23 PM   #10 (permalink)
Hey, Im not able to see pics at this late date of diffuser, can you send to me or repost, really interested for my 2013 Spark, thanks
