Old 12-22-2011, 03:23 PM   #11 (permalink)
90 day: 19.36 mpg (US)
Glad you got those links up. Some of the other Cummins-specific information is, as you noted, for big truck operators. There is at least one Cummins calculator about truck spec, use, etc, that always recommends a higher rpm than pickups in general use will need, as with this post by Hohn, a Cummins Engineer.
Another post by that same gentleman goes into some more depth about proper rpm range for fuel economy.
Old 12-22-2011, 03:47 PM   #12 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
hey slowmover do you yank that trailer around all the time . what is the difference in mileage with and without it.
Old 06-29-2015, 05:46 AM   #13 (permalink)
Around fifteen. This is South Central US. Solo at the same speed is 24+ with 1,000 lbs in truck bed.
Old 09-26-2016, 08:53 PM   #14 (permalink)
(Here's that earlier Cummins info thread about FE)
