Old 06-04-2014, 03:28 AM   #1 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
custom scangauge install in New Beetle
I have started the personalization on my Beetle
The rounded dash and steering column parts have a nice OEM look, but are not good for new radios, little doodads like a scangauge, etc.
I had it velcroed to the top of the column, but it obscured the fuel and tach, and I had to reach behind it to set the trip meter. Sorry, no before pics but it was about 3/4" higher.
I removed the steering console top and laid out a hole in it, 13/16" back from the front edge and 1" wide by about 4" long to start. The console top is held on by two #1 phillips screws from below.
I started cutting it in with a razor knife. Not too pretty yet, but I trimmed it up once I had the hole through.
Once I had the hole cut, it was obvious I needed to go wider. The shape of the hole was defined by the profile of a high part of the cover.
I cut it a little wider yet, and this is what it looked like from the side.
On the top of the steering column there is a clip for a set of contacts, probably the horn and airbags. I took the scangauge apart and determined I could notch into the gauge itself to miss that clip.
I centered the gauge up and marked it with a pencil, and cut that with the razor knife.
I removed the board and display, of course.
Here is the final look. Before, the wire exited the right side of the gauge. Now it goes out the back and is totally hidden.
In that photo the column is adjusted all the way up, and is about 3/4" back from the front stop. That is the only limitation, you can't push the column all the way forward.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
The Following 4 Users Say Thank You to skyking For This Useful Post:
Dave's Civic Duty (06-24-2016), Joggernot (04-18-2016), mcrews (06-04-2014), Xist (06-24-2016)
Old 06-04-2014, 06:42 AM   #2 (permalink)
What brake pedal?
digital rules's Avatar
Silver Streak-5M - '05 Toyota Corolla S
90 day: 42.41 mpg (US)
Nice work Skyking!! Any glare issues?
The Following User Says Thank You to digital rules For This Useful Post:
skyking (06-04-2014)
Old 06-04-2014, 09:19 AM   #3 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Big thumbs up!!!!
First rule of add-on:
1. put them in the same line of sight as other gauges!!!!
Second rule:
2. Mount them securely!!!
maybe you could add your picks to this thread?
http://ecomodder.com/forum/showthrea...e-18431-2.html
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-04-2014, 12:10 PM   #4 (permalink)
skyking's Avatar
None at all. I had it velcroed to the same place for months. It blocked the fuel gauge and the trip meter button. Now it blocks nothing.
2003 TDI Beetle
2002 TDI Beetle
The Following User Says Thank You to skyking For This Useful Post:
Xist (06-24-2016)
Old 06-04-2014, 12:19 PM   #5 (permalink)
skyking's Avatar
I did not want to clutter up the column and stock gauges further, but wanted full instrumentation on my diesel so I drilled the dash way up by the VIN tag and stuck a 3 in 1 combo gauge up there.
2003 TDI Beetle
2002 TDI Beetle
The Following 2 Users Say Thank You to skyking For This Useful Post:
Old 06-24-2016, 10:17 AM   #6 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
Thanks for the link here sky. Think I'll get another ScanGaugeii. Advance Auto Parts has them for 20% off if ordered online, then pick them up at your local store.
BTW were you on Mopar1973Man.com? Thought I may have read your posts over there.
Dave3500
Old 06-24-2016, 10:23 AM   #7 (permalink)
skyking's Avatar
Not on his site as a member, but he is on a few forums I frequent. Feel free to copy my cut out, and I can get you the original images and also take some measurements.
The Scangauge has a nice blue color option that really is close to the dash light color. Looks great.
2003 TDI Beetle
2002 TDI Beetle
Old 06-24-2016, 10:35 AM   #8 (permalink)
Thanks for being so helpful! What holds the SG in place, looks level too!
Great job,
Dave
Old 06-24-2016, 10:40 AM   #9 (permalink)
skyking's Avatar
It's so tight in there, I think it is just a patch of double back tape.
2003 TDI Beetle
2002 TDI Beetle
Dave's Civic Duty (06-25-2016)
Old 06-25-2016, 04:42 PM   #10 (permalink)
Thanks skyking, good to know! BTW, I like your 49.05 MPG. What is your mix of city driving? Open road? Do you keep it under 65MPH?
Thanks,
Dave
