Old 04-10-2017, 01:08 PM   #21 (permalink)
Dark Egg - '12 VW Touraeg
This is thing is harder to start then a nuclear reactor but very few wear parts. I love the "glow plug". I wonder if a roach would work just as well.
https://youtu.be/01Sr8S9uQMc
Old 04-10-2017, 10:43 PM   #22 (permalink)
That was a plot point in Flight of the Phoenix.
Brings new meaning to 'hammer down'.
Old 04-11-2017, 07:58 AM   #23 (permalink)
Send a message via MSN to markweatherill
the oil drain down question
Oh man! Slick 50, Castrol and all the others must one day answer for the received wisdom of the masses that 'most engine wear occurs at startup'.
If so, it's more due to corrosive combustion by-products during warmup and not so much of that there cold-start metal-to-metal contact.
(Oh, and once the engine is warmed up, not every start is a grinding big-end rumbling cold start)
Old 04-11-2017, 11:38 AM   #24 (permalink)
ScanGauge <3
ThermionicScott's Avatar
...90 percent of starter-motor brush wear occurs not during cranking, but during the coast-down after the start has finished.
I did not know that! Thanks for posting, MetroMPG.
Best tank (so far): 32 MPG
Old 04-11-2017, 12:18 PM   #25 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
That part was news to me as well.
And I don't understand why that's the case, unless it's simply because the motor spends more time spooling down than it does spinning up & cranking.
Old 04-11-2017, 02:10 PM   #26 (permalink)
Makes sense. But how does that cause brush wear? Isn't that more of a stress on bearings/bushings?
Old 04-13-2017, 10:41 PM   #27 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
If you pull apart a DC motor, you'll find the negative brush is often worn about twice as much as the positive brush, due to the flow of electrons. As such I think most wear occurs while electrons are flowing.
Old 04-14-2017, 12:07 AM   #28 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
They started a new no idling policy at work. As one of the mechanics I was worried about the meter reader trucks. These guys read over 100 meters a day, that is a lot of start/stops each day. This has been going on for about 3 years now and I really haven't seen too many new problems. Luckily we have rotated out the 4.2L Ford v-6 trucks. They were the problem children before the new policy, I think we are down to 1 in my yard and it gets little use.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 04-14-2017, 09:51 AM   #29 (permalink)
...beats walking...
Yep, it's the same process as happened on ignition breaker points, where "pitting" was caused by current-flow actually causing metal-transfer ("pitting") which was offset by adjusting the value of the condenser (capacitor):
"...a MINUS (pit) on the MINUS (neg.terminal) is a MINUS (too little capacitance)..."
Old 04-14-2017, 11:38 AM   #30 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I've have been working on car & trucks for a living since 1975.
I have seen many different types of starter issues.
I have also noticed that starters on cars with smaller diameter (larger gauge number) primary battery cables seem to die sooner.
The starter in my current DD is 325,000 miles old.
I have buttons on the dash to stop/start the engine.
I use these while driving through town & at lights.
When I put the buttons on the dash, (in summer 2006) I also replaced the OEM battery cables with heavier ones. I used 0gauge (single aught for you old guys) wire & made the cables to my specs.
Negative goes directly to the starter mounting bolt @ the transmission, then a daisy chain ground through the engine bay. This will cause noise in your FM stereo so use aux input or Cd's or a ground isolator module.
Positive to the starter then OEM cable to the alternator.
I've had no issues with my starter and it spins noticeably faster than a car with OEM cables.
High amperage draw kills starters.
Ohms law
Ohms Law Calculator
says that watts = amps x volts,
by reducing the amperage draw on the starter I have effectively increased the voltage to the unit and increased it's life.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
The Following 3 Users Say Thank You to metroschultz For This Useful Post:
California98Civic (04-15-2017), Fingie (04-14-2017), MetroMPG (04-14-2017)
