Old 04-09-2008, 10:14 PM   #21 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Jeep Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Dodge Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Ford Escort LX
I believe I read somewhere where wheels and tires are around 10-15% of drag. lowing the vehicle causes the wheels to be hidden more, and they don't stick out as much.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 04-09-2008, 10:26 PM   #22 (permalink)
Send a message via AIM to Gone4
It also seems worth mentioning that lowering or raising the ride height can change the critical Reynolds number. The flow at higher heights will be closer to a free flow conditions and lowering it will approach a more constrained flow situation and cause the transition to turbulent flow to occur sooner. For rough undersides this is impossible to predict but for smooth undersides this is something that should be considered.
Old 04-09-2008, 10:44 PM   #23 (permalink)
OK, just to confuse things further, here's something I ran across late today. It's from an SAE paper, 951906, "Vehicle Design Strategies to Meet and Exceed PNGV Goals" by Timothy C. Moore and Amory B. Lovins, found here
https://www.rmi.org/images/PDFs/Tran...nStategies.pdf
The following comes from page 11:
"Rather than smooth the underbody and attempt to tuck chassis
components up out of the flow, the industry strategy has
tended towards air dams below the front bumper to force much
of the flow around the vehicle rather than under. This needlessly
increases frontal area and leads to the erroneous notion
that achieving very low aerodynamic drag requires extremely
low ground clearance[5]."
Footnote [5] says:
"If chassis components are streamlined or otherwise covered
by a smooth floorpan to prevent interference drag, there is
little reason, beyond the limited exposure of more of the tires’
frontal area, to prevent the airflow from passing under the car
(P. MacCready, AeroVironment, personal communication,
April 1995). Allowing the airflow to pass under the car can
actually aid in eliminating lift-induced drag."
In case you are not familiar with "P. MacCready" or AeroVironment, see
http://en.wikipedia.org/wiki/Paul_MacCready
If you look at the Viking cars by Dr. Seal, mentioned by aerohead above, you can see that he took pains to deflect air from in front of the wheels, but did so without front air dams or lowering ride height. The entire collection of cars can be seen from here (click on the boxes to see photos):
http://vri.etec.wwu.edu/cars.htm
Sadly, I have not found anything in the way of technical descriptions of these cars beyond the one paper here:
http://vri.etec.wwu.edu/hybrid_paper.htm
About 3/4 of the way down the page is a nice paragraph on aerodynamic drag reduction which does not include lowering ride height as one of their strategies.
Now, you will notice that nothing I've quoted here says that lowering ride height *won't* decrease drag--it just says you don't need to lower the ride height to achieve low drag.
--Steve
Last edited by SteveP; 04-09-2008 at 10:46 PM.. Reason: added "or lowering ride height"
Old 04-09-2008, 10:52 PM   #24 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
I got this brillant idea a couple years back that my windshield was too steep and needed to be tilted back, so, I cut a couple inches of an old set of rear springs and put them in. (under body stock)
Well it just killed my top end and mileage, so I put the stock springs back in.
Mileage and top end back to normal.
So I wonder if I raise the rear an inch what will it do?
Old 04-09-2008, 10:59 PM   #25 (permalink)
GenKreton, that is certainly an explanation that would fit the observation that lowering ride height on a smooth-bottomed vehicle increases the drag--the smooth underbody would have laminar flow for some distance before the critical Reynolds number would be reached which would turn the flow to turbulent. Anything that would move that point closer to the front, such as creating a more constrained flow condition, would presumably increase the drag.
Thanks for mentioning that....
--Steve
Old 04-09-2008, 10:59 PM   #26 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
So... I did some CFD runs for the HPV fairing... Rolling wind tunnel, 30mph, 68 degree dry air..... Then I lowered it, from 2 inches to 1 inch.... And I got a decrease in drag... About .3 pounds... Significant for the amount of total drag on the fairing No wheels or anything getting hidden - purely height change
The fairing is a streamlined body - flow never goes turbulent....
Just food for thought
Soon, I'll have a nice models of production cars to test
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-10-2008, 12:10 AM   #27 (permalink)
trebuchet03,
I checked out your build thread for the HPV fairing (very cool project, BTW) and noticed that you claimed a Reynolds number of 184. Not 184,000 but 184. Unless I'm totally misunderstanding what you're reporting, that really doesn't seem reasonable--using a characteristic length of 60" and a speed of 30 mph in 20C air I get a Re of 1.4E6. Just to make sure, I did a little looking around the net and even the Re for a bicycle helmet is 1e5.
What am I missing? I ask, because if the Re is really out of line with cars, then your ride height experiment might not be transferable to a car.
--Steve
Old 04-10-2008, 12:42 AM   #28 (permalink)
MechE
Originally Posted by SteveP View Post
trebuchet03,
--Steve
I'll have to see if I can pull the characteristic length out of the model.... It's not like a chord of an airfoil - there's a lot of compound curves in there (and I really don't want to start hand calculating that) :/ But I'll double check <-- mind you, runs I do personally are with software that doesn't give Re# data
I'm not looking for transferability - but there was a blanket statement made that applies to vehicles with streamlined undersides.
All that aside - we should have tuft testing data next week So if there's some obvious flow issues, we'll see them
Old 04-10-2008, 02:38 AM   #29 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
diesel_john -
I was thinking something similar, aka only lower the front end. Are you thinking that the "larger volume" open space at the rear would aid in air exiting faster at the rear?
CarloSW2
American Solar Energy Society
Old 04-10-2008, 02:52 AM   #30 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
Another advantage of lowering a car is that the front fender well gaps are smaller with the wheel sitting higher up in them. This keeps some of the wind that the tires are blowing forwards from getting into the air on the sides of the car. You can see that on a rainy day the front wheels throwing water forward and out of the fender wells.
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 130 02-10-2015 08:50 PM
Aerodynamics Seminar #2 - by Phil Knox MetroMPG Aerodynamics 2 05-10-2013 05:34 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
How to reduce drag of surfboard roof racks? Palionu Aerodynamics 11 04-28-2012 02:15 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
