10-27-2015, 11:51 AM
DZUS fastened MOON DISC wheel covers?
has anyone used the "DSUS" fasteners that you WELD ON to the wheels?
specifically on Aluminum wheels?
was it hard getting the tabs welded on?
how was the fitment?
how are they holding up?
have you had any issues? (balancing, cops, tire shops)
any input would be greatly appreciated
I'm seriously thinking about doing this on my 2010 Prius
the Wheel Covers
Dzus Fastened MOON Disc
Weld on fasteners
Dzus Tab Kit
Jig for fastener placement
Dzus Weld Jig
2005 GTO 6.0 V8 (600hp)
1991 Geo Metro 1.0 3/5 base
2010 Prius II (replaced 2001 Tahoe 5.3 V8 April 2014)
1994 F-350 7.3 TurboDiesel (Rollin' Coal)
Reason: added pics
The Following User Says Thank You to KrautBurner For This Useful Post:
10-27-2015, 12:40 PM
I drilled and tapped my rims to fasten the moon discs on Ron Burgundy, but I'm also interested to see if anybody has done these. If you end up welding them on your rims make sure you document the steps real good, I might change mine out down the road for the Dzus fasteners.
10-27-2015, 01:10 PM
Be very careful. Not all aluminum alloys are weldable. If you try to weld the wrong alloy, it will crack on its own without any load on it. Even a weldable alloy will have a heat affected zone around the weld that's weaker than the rest of the wheel.
The Following 5 Users Say Thank You to JRMichler For This Useful Post:
10-27-2015, 03:08 PM
Dzus and aluminum
I don't believe that MOON offers the kit for aluminum wheels at all.These covers are intended for LSR racing and most teams run AERO (R) steel racing wheels as does NASCAR.
If your aluminum wheels are rigid,and don't flex at all,you could drill and tap for the 6-hole MOONs.They're just as aero and a fraction of the price of the 3-hole Dzus-type.
10-27-2015, 05:11 PM
It doesn't look like OP was asking about a productized solution.
The specialized tooling required would be a Bridgeport mill or something similar to chuck the disk in and mark the holes at 120°. 64th inch accuracy should be sufficient. Then a flaring tool to bellmouth the holes in the disks. The spiral springs might attach directly, else the flat square mount could.
10-27-2015, 05:24 PM
T-100 Road Warrior
Not sure if something like this will fit the steel rims fer the Prius or not...
Gen II Non-Beadlock wheel covers
You might be able to adapt this type of technology to yer rims.
Dark Aero-The world's first aerodynamic single wheel boat tail!
10-27-2015, 06:50 PM
Moderator
It will be much easier and cheaper to screw pans onto the plastic Prius wheel covers....
If I ever do change my setup, I would get narrow steel LSR wheels; you can get them made in custom widths and have the Dzus tabs welded on. The hard part would be finding tires to fit, and cost.
10-27-2015, 09:13 PM
#9 (permalink)
Well, then, the trick would be to get a 4x9" wheel and then you could fit the Bridgestone Ecopias from the BMW i3.
Here's a 15 page thread on them.
M oon will make you the disks.
03-20-2018, 09:01 AM
#10 (permalink)
I just picked up a set (4) of three spoke Ford Explorer steel rims for this purpose (for a reasonable $80). I ordered two of the Moons and the Dzus template which should arrive sometime this week. I’m looking forward to seeing how they turn out. I think l’ll be able to duplicate this setup for the other two wheels for less money in the future.
The Following User Says Thank You to Interstatement For This Useful Post:
