Old 06-01-2014, 09:59 PM   #281 (permalink)
blownb310's Avatar
Saab EV - '19 Chevy Bolt EV LT
Pierre - '07 ZENN MC2 Base
Great update Francis. Glad to see that you are getting ready for the SMCC Economy Run next week.
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
The Following 2 Users Say Thank You to blownb310 For This Useful Post:
echo-francis (06-01-2014), HyperMileQC (06-01-2014)
Old 06-01-2014, 10:40 PM   #282 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Wow! Lotta nice little jobs there. Did you go for a lighter flywheel and clutch? How much lighter?
EDIT: I just re-read you garage listing of mods. The EWP and radiator switch idea for DFCO cooling is rad. I have been using DFCO jn a somewhat similar way, and I have seen how much cooling it can produce on long hills. Your mod must really cool a hot engine fast!
Old 06-03-2014, 07:41 PM   #283 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
the flywheel is 8lbs vs 15 for the oem the pressure plate is 7.5lbs vs 9 lbs oem but i dont know why it is more light besause its not "lightweight" its oem replacement.
i cant use the original purpose of the The EWP and radiator switch because my alt is not rotating but is has been usefull to cool my engine in unexpected traffic or recently because my starter is going away and i have to idle at red lights and this create too much heat ( i am to lazy to remove some insulation) but i replace my starter tomorrow
and just because my starter is going away i am getting more red lights and traffic then ever
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
Old 07-19-2014, 02:31 AM   #284 (permalink)
40-60-40 MPH P&G
back to first place
MPG=1 TIME=0
Old 07-19-2014, 02:47 AM   #285 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
I am impressed by your numbers. I lack a manual trans (oh how I want one again, as much for myself as for MPG), but then again the car was free.
I commend you and will try to take the time to read the whole thread to see what I can/am willing to adopt.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 07-19-2014, 09:53 AM   #286 (permalink)
40-60-40 MPH P&G
keep in mind that ROI is not in the equation when I do mods but feel free to copy me if you want
MPG=1 TIME=0
Old 08-15-2014, 12:00 PM   #287 (permalink)
starting with a brick
francis what a great project. I may pick up an old Echo soon and start playing with it, a whole lot of good data from your threads. Merci
'02 Forester slushbox
Old 10-21-2014, 03:10 PM   #288 (permalink)
Any update on the car Francis? Any mods planned or in the works? I love this project.
Old 10-22-2014, 12:22 AM   #289 (permalink)
40-60-40 MPH P&G
time for a update
first, a review on my fidanza flywheel. my acceleration is faster, starting from a stop and shifting are not harder idle is the same, but it rev higher just after starting or bump starting and bump starting is harder.
this summer I did some maintenance on the car:
remove the rust on the floor
clean the carpet at the same time
and install a smaller driver side mirror from a 2000 toyota echo
you know what to do if you want to know my planned mod
and some of these will be done this winter
MPG=1 TIME=0
The Following 2 Users Say Thank You to echo-francis For This Useful Post:
HyperMileQC (10-22-2014), mikeyjd (04-06-2015)
Old 12-11-2014, 01:59 PM   #290 (permalink)
40-60-40 MPH P&G
update
i received some parts for my big maintenance project
and I found a manual steering rack from a US toyota echo in a salvage yard
i got new tie rod end for it because they are different from the one on the power steering
and I am slowly removing tape on the car by replacing taped chloroplast by black chloroplast
wheel covers
whiper cover
i bought a imax b6 balance charger to charge and balance my DIY 18650 battery packs
and I power it with a DIY computer power supply
i received a flashlight from the internet and it came with a ultrafire 4200mah 18650 battery and I tested it with the imax b6
only 689mah
MPG=1 TIME=0
alt delete, belly pan, electric water pump, grill block, hypermiler, modding, toyota echo
