12-10-2017, 12:19 AM
#21 (permalink)
マット
How well did this end up working? I have been thinking about taking off my power steering, but I have hydroboost.
Based on your results, do you think a similar system would be worth (in terms of fuel savings) hooking up to the hydro boost on my Astro? Opinions are appreciated.
Thanks, Matt
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
12-10-2017, 07:38 AM
#22 (permalink)
I haven't been able to do much with it at all.
All I did so far was test it and found that it works really well.
12-11-2017, 10:37 AM
#23 (permalink)
Not interested in swapping a Saturn Vue steering column (with the electric power steering) instead?
12-11-2017, 10:49 AM
#24 (permalink)
The oems are continuing to use hydraulic power steering with worm gear box in hard working applications.
07-05-2018, 09:00 AM
#25 (permalink)
Have you considered using something OEM like an A class power steering pump. It runs off 12v. I've thought about using one, and having it only turn on when the steering wheel is not directly straight up (using a reed switch and a magnet on the steering wheel).
08-29-2018, 10:31 AM
#26 (permalink)
Got a Citroën/Peugeot electric pump for my Citroën. 3 wires to hook up (power, ground, and a switching wire to the relay mounted on the pump, heavy fuse is included). Later models have more electronics, to make it speed-variable. I suppose you could make it user-adjustable and/or turn off at the dash.
On the upside, unlike the belt driven power steering on my other car, this one seems to freely let the oil flow forward when the pump is not running, steering just reverts to manual heavyness, instead of nearly-locked-solid like the mechanical pump.
'97 Ford Escort 2010-2010†
'90 Citroën AX GTI 1.4 mpi 2010-2012†
'96 Citroën AX Diesel 1.5D 2012-2016†
'95 Citroën AX w/ TU5J4 1.6 16V swap 2015-2016†
'92 Citroën AX w/ TU5J4 1.6 16V swap #2 2016-
'02 Renault Mégane wagon 1.6 16V on LPG 2016-
08-30-2018, 09:29 AM
#27 (permalink)
You got a link or part number or what year/model citroen these pumps are on. Sounds ideal
08-30-2018, 10:58 AM
#28 (permalink)
With various different reservoir shapes, power connectors and with/without built in speed related electronics, in almost any Citroën car from 2000 on, several Peugeot models too. Some models could have either electric or belt driven depending on what other options the car had, I don't really know if theres a whole list, but googling "Citroën electric power steering pump" will give plenty of results.
I'd say the Saxo/106 one is probably the most easiest to adapt, it has a remote mount reservoir (really just a fill cap on a hose, the pump also has internal capacity) so you can bury it somewhere down low in the engine bay, simple wiring (the wires come out with a connector that you can replace if needed), and if you get the whole thing with mounting bracket and it's little wiring loom it's even easier to make work.
