Old 07-04-2016, 01:02 PM   #11 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
I think the relative definition of load is the percentage of air flow compared to WOT at that engine speed, and the absolute load is the percentage of air flow compared to cylinder displacement, which is like volumetric efficiency.
About PID Calculated Load Value » OBD-II Resource
Here's some good discussion on it.
https://www.physicsforums.com/thread...e-load.703167/
If you have a BSFC map, you can use that load and rpm to figure out engine efficiency.
The Following User Says Thank You to roflwaffle For This Useful Post:
Xist (07-04-2016)
Old 07-29-2016, 09:03 PM   #12 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Originally Posted by me and my metro View Post
I ran our 60 liter Diesel genset yesterday for its monthly exercise... it burns 125 gallons/hour at rated output of 2 megawatts. The four huge turbos sure sing at 2 megs.
You need to cut back on your electrical consumption. Consider turning off the PC when you aren't using it, and switch to CFL bulbs.
Originally Posted by spacemanspif View Post
What are your cars idling at?
The Prius doesn't idle, or at least during the few times it does, the data isn't relevant because it's in warm-up mode, and purposely wasting more fuel than it needs to.
My Acura TSX 2.4L I4 engine idles at 25% engine load with the manual gearbox in neutral, and parking brake set (no brake lights on), no HVAC. Timing advance bounces around 9 degrees, but I'm also running the minimum octane instead of the recommended 91. Fuel consumption is 0.18 gal/hr.
The relevant info is instant fuel consumption.
I'd sure be curious if there is any difference from when I had the stock pulley ratios installed. I didn't find this site and get a gauge until after I had swapped it out.
Old 08-04-2016, 04:18 PM   #13 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
I ran our 60 liter Diesel genset yesterday for its monthly exercise. ....<snip>..... it burns 125 gallons/hour at rated output of 2 megawatts. The four huge turbos sure sing at 2 megs.
Hospital? Nuclear silo? Server farm? Really big subwoofers for your garage band? Where do you feed that beast?
