Old 07-08-2013, 03:49 PM   #1 (permalink)
Jack-Lee's Avatar
Partygurke - '90 VW Polo 2F
Rodi - '04 Smart Roadster Coupe
Engine mod (BJ 1991)
Hi,
my project go forward.
Beside the aerodynamic mods i modified the engine.
Currently a 55PS Mono-Injection 1.3l assembly are installed.
New Engine:
modified "3F" 75HP Multipoint 8V
Modifications:
-new DIY Manifold (oscillating tube charging)
-new DIY Exhaustsystem
-higher compression ratio
-modified head ("Back Cut" Valves, polished exhaust port)
-modified controlbox (no wide-open-throttle enrichment, deceleration fuel cutoff from 1200U/min [currently 2000U/min], mached to "super" gasoline)
Result:
-114Nm at 2000U/min !
-Max 131Nm at 4500U/min
-Peak Power 71kW (95Hp)
-BSFC 256g/kWh at best point (about 2500U/min), 265g/kWh average from 2000-4500U/min
Stock 3F:
-97Nm at 2000U/min
-Max 99Nm at 3200U/min
-Peak Power 55kW (75HP)
-BSFC 263g/kWh at best point (about 2000U/min), 275g/kWh average from 2000-4500U/min
currently Engine (AAV 55HP)
-88Nm at 2000U/min
-Max 95Nm at 3500U/min
-Peak Power 45kW (55HP)
-BSFC 272g/kWh at best point (about 2000U/min), 280g/kWh average from 2000-4500U/min
So i save only 5% fuel, but the engine is almost new after the rebuild, so the difference is bigger.
Also i could drive with a looooonger gearbox
by the way, ive double the output power
The picture show the difference between stock and mod.
Sorry for the grid, the two diagramms had not the same y-axis.
The Following User Says Thank You to Jack-Lee For This Useful Post:
oldtamiyaphile (01-13-2017)
Old 07-10-2013, 06:30 AM   #2 (permalink)
Jack-Lee's Avatar
Hi,
i modified the engine again.
Smaller! runners
smaller valves
shorter Manifold with smaller diameter
Result:
136Nm! @ 4500U/min
better enginie efficenty
In the picture: comparation between my currently and the next enginie
Old 07-10-2013, 08:01 AM   #3 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Looks promising, keep up the good work Jack.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 01-16-2014, 02:26 PM   #4 (permalink)
Jack-Lee's Avatar
Hi,
latest Version with 141Nm@4500U/min and 92HP@5000U/min
And a few Pics from the first "real" steps.
The engine are now by the tuner.
-new pistions (incl. drill and honing)
-new valves
-new bearings
-new sealing
-higher compression
-other cam
-other alternator
-DIY intake manifold
-DIY exhaust
ID:	14439   Click image for larger version
ID:	14440   Click image for larger version
ID:	14441   Click image for larger version
ID:	14442   Click image for larger version
ID:	14444   Click image for larger version
Old 01-16-2014, 03:14 PM   #5 (permalink)
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
That's way cool but could we get more pics of oily parts and namely your DIY parts, assembled engine and such.
So you have the facility to dyno run the engine or is it an engine simulator ?
I would really enjoy more details like valve size before and after and such.
Also, what is the cam duration ?
Old 01-16-2014, 03:17 PM   #6 (permalink)
Jack-Lee's Avatar
Hi,
my english is bad, so i doesnt write all the think that i could write.
Name the Parts? There's normal Motorparts (Pistions and so on)
I clean the Head and mill a little "combustion chamber". Without sharp edges the pinging risk is lower (other changes at the pistion)
The Exhaust is finished, but i had no photo on my PC :/
The Valve are standard, but the valveseat is changed an the valves milled to be lighter (lower springstiffness -> lower losses)
The data in my last post are simulated. But the Motor (when finished) are fine-tune on a dyno.
Old 01-16-2014, 03:22 PM   #7 (permalink)
OldContinents
You little teaser ;-)
If your english is not good (not buying it any second) that gives you more of a reason to post more pics !
Also, cam duration, valves diameter and CR you can write in german ;-P
Old 01-16-2014, 03:52 PM   #8 (permalink)
What are the units for your BSFC.
Those are very low numbers.
Old 01-16-2014, 03:52 PM   #9 (permalink)
Jack-Lee's Avatar
Hi,
Cam Datas:
CAM from a Polo 6N with ABU Engine
111.5° ATDC
Duration @ 1mm 211/215
Max Lobe Lift 9.4/9.6
hydro"stößel"
Valves:
Standard from "G40" (exhaustvalve with natrium)
Intake Valve:36mm (Port 30,5mm)
Exhaust Valve:29mm (Port 26,8mm)
Valves polised and the ports are aerodynamik tuned
Intake Manifold:
Length 300 (standard about 130)
Runner Dia: 30,5mm
Made of Alu or CFK, im not sure what material i use.
Exhaust "Fächerkrümmer" 4:2:1
Section 1 (from each cylinder): 32mm (the "step" from head to exhaust minimized the reflow in the cylinder)
Section 2: (for 2 cylinder) 45mm
Section 3. (for all) 50mm
@rusty lug: What numbers you mean?
Old 01-16-2014, 04:11 PM   #10 (permalink)
The chart you posted for bfsc.
Gasoline engines usually come in at right about 0.48 pounds/horsepower*hour in British units. A very good gasoline engine or a basic diesel will dip down to 0.42 lb/hp*hr. Large diesels used in power generation or ocean going power plants can dip down to 0.28 lb/hp*hr.
Your simulated engine is below that at just below 0.25, but it may be an issue of unit measurements. I just wanted to clarify.
