Old 06-29-2015, 11:21 PM   #51 (permalink)
Excellent! Thanks for the update. Pictures are fine.
I'm really looking forward to seeing how the cam effects things. I was actually just talking with MetroMPG today about altering my Metro's cam timing.
Old 06-30-2015, 07:50 AM   #52 (permalink)
Cool, I fooled around with a custom Metro cam sprocket a long time ago but never really dialed it in.
The Miata was fitted with an adjustable cam sprocket a few years ago and after some fiddling it appeared to make a difference. Hopefully this experiment will confirm my original findings.
Locating an adjustable sprocket to fit the B3 engine was more or less an educated guess. Ironically sprockets for a 1.6 or 1.8 Miata engine will work.. of course the B3 only needs one sprocket instead of two. Buying the set allows me to put one on the Miata and one on the dyno.
I went with a set of el-cheapo ebay sprockets because ...well they were cheap. Better quality sprockets were available but the cheap ones were identical for intake and exhaust whereas the more expensive ones are different. The difference is limited to the silkscreen printed on the sprockets.
The red units are El-Cheapo sprockets of questionable quality. The blue sprocket is a better quality CorkSport... but I only had one.
Stay tuned!
G10 powered Mazda MX5 45+ MPG(sold)
B3 powered Mazda MX5 40+ MPG
Old 07-09-2015, 07:32 AM   #53 (permalink)
Just a quick update...
I had some issues with the dyno electronics and didn't get any tests done. The new parts should be arriving this week and the dyno will be back in action . hopefully I'll be able to start posting results by this weekend.
The Following 2 Users Say Thank You to fujioko For This Useful Post:
Daox (07-09-2015), Joggernot (07-09-2015)
Old 12-08-2015, 09:01 PM   #54 (permalink)
Got it fixed?
