11-29-2017, 11:04 AM
#11 (permalink)
I ran 75% antifreeze mix in my suburban once, took me a while to figure out why it was running hot. Once I dumped out some of the antifreeze and replaced it with water it was back to normal.
The Following 2 Users Say Thank You to oil pan 4 For This Useful Post:
11-29-2017, 02:18 PM
#12 (permalink)
Was that a nice and hot or a too hot scenario.
11-29-2017, 04:12 PM
#13 (permalink)
Hitting 230°F on a warm day not towing anything is bad.
11-29-2017, 05:13 PM
#14 (permalink)
Were you driving vertically? Attempting to escape Federales? Please tell us how you achieved this feat!
11-29-2017, 05:50 PM
#15 (permalink)
Originally Posted by Daox
Added to the list! Those are good. Like any modification you must be aware of its consequences and thus check your oil more regularly.
I don't think that you will reduce your warm up time much, if any, by using a higher concentration of antifreeze, but you WILL reduce heat transfer quite significantly, meaning that the cooling fan will have to run more and you will have to have larger cooling openings. Detonation will also be more likely with reduced heat transfer because hot spots can develop. Glycol is also much thicker than water, so your water pump will take a lot more energy to spin, further offsetting any gains from faster warmup. If your goal is to reduce heat transfer, why not use 100% Propylene glycol antifreeze, aka Prestone Lowtox or something like it? Straight PG won't freeze unlike EG and doesn't transfer heat as well as EG based coolant.
11-29-2017, 05:52 PM
#16 (permalink)
10) Concentrate the coolant to approx. 75% glycol
I don't think that you will reduce your warm up time much, if at all, by using a higher concentration of antifreeze, but you WILL reduce heat transfer quite significantly, meaning that the cooling fan will have to run more and you will have to have larger cooling openings. Detonation will also be more likely with reduced heat transfer because hot spots can develop. Glycol is also much thicker than water, so your water pump will take a lot more energy to spin, further offsetting any gains from faster warmup. If your goal is to reduce heat transfer, why not use 100% Propylene glycol antifreeze, aka Prestone Lowtox or something like it? Straight PG won't freeze unlike EG and doesn't transfer heat as well as EG based coolant.
11-29-2017, 06:24 PM
#17 (permalink)
Eco-ventor
Just for the record: I had my glycol at 75%, full grill block, and my engine covered in bubble wrap, and it never over heated.
I guess YMMV.
12-03-2017, 01:58 PM
#18 (permalink)
Automotive antifreeze – viscosity table and viscosity chart
Dot know if this si for EG or PG
If you want to run strate then run E
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
12-03-2017, 02:56 PM
#19 (permalink)
Straight antifreeze will freeze at -15c? Interesting.
I wonder how much higher the boiling point is when considering the additional pressure in the system (regulated by the rad cap)...like the difference between boiling water at sea level and at 8000ft.
12-03-2017, 08:57 PM
#20 (permalink)
Where I am at 4400ft the boiling point is 208°F.
