02-20-2017, 03:04 PM
Finally added side skirt.
Seems to help. I drive 360 miles total every other weekend to take my kids home and I never made it above 34mpg on my Fiesta. Last two trips I averaged 35 then 35.3mpg. With a mix of up hill and downhill. Seems to be with the 22.00 I spent. Same gas station also.
The Following 5 Users Say Thank You to syllinx For This Useful Post:
02-21-2017, 07:56 PM
Four Thanks but no comment?
How do you attach them? Any thoughts about adding spats to the ends?
02-21-2017, 10:09 PM
I just us screws with lock washers.
ProFlex ProFlex 6 ft. Paver Edging in Black-1260-HD - The Home Depot
Not sure about adding spats yet. Just wanted to see if the screws vibrate loose first.
The Following 2 Users Say Thank You to syllinx For This Useful Post:
02-21-2017, 11:35 PM
Cyborg ECU
Looks like mayb just an inch or two extension below the running board, no? I like that it is in black though. I used white gutter, cut it, painted it flat black. But you can imagine I have had to repaint in whole or part twice since installing because any scratch exposes white under the black.
02-22-2017, 07:09 AM
Looks good. Subtle, could probably have gone lower but it's almost certainly going to have no negative consequences at that length.
02-22-2017, 07:49 AM
Originally Posted by syllinx
Installed upside down, right?
I wonder about the other sizes available, like with deeper vertical flanges for instance.
What's this one, about 1-3/4" deep?
03-20-2017, 03:58 PM
Wow...i guess every Lilttke bit helps but I wonder if gping closer to the ground would help more?
07-14-2017, 02:49 PM
Let it grind, right?
There're lots of things that would help more. This would be about ROI. Maximum Return On minimal Investment.
Oh, welcome to Ecomodder.
