09-18-2017, 04:44 PM
#451 (permalink)
Master Novice
Originally Posted by Bill the Engineer
Not much photogenic from this weekend. Nothing is so exciting than scraping 1/4 inch thick undecoating from a 50 year old wheel well.
Hey, at least it's progress...
Bill the Engineer
That's weight reduction for better mileage in town. It's all good.
The Following User Says Thank You to elhigh For This Useful Post:
09-18-2017, 06:53 PM
#452 (permalink)
We used a tank of Liquid nitrogen to strip the undercoating and insulation of a car,, worked very well. But best done outside and wearing a full set of heavy heavy raingear..
If it has a motor its worth playing with.......
The Following 2 Users Say Thank You to dwtaylorpdx For This Useful Post:
09-20-2017, 06:48 PM
#453 (permalink)
Reminiscing on my birthday. Just found some photos from when I first bought the Firebird in 1979. It still had the dealer's tag on it when I first put it in the garage. BTW, that's my late Dad in the photo, not me. My wife and I got lots of miles and smiles out of the Firebird before I put it away for the "someday" project (now known as the Firebrid Project.)
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
09-20-2017, 08:54 PM
#454 (permalink)
Some day your blueprints will come?
The Following 2 Users Say Thank You to Xist For This Useful Post:
09-20-2017, 10:58 PM
#455 (permalink)
A few questions:
When is your b-day?
Are you going to keep those fender-mirrors?
What about that pod in the hood? Was it used as a housing for the tach? Since there is no tach in the Prius, how could you repurpose that feature?
09-21-2017, 02:47 AM
#456 (permalink)
Originally Posted by cRiPpLe_rOoStEr
A few questions:
Apparently it could be connected, with a bit of electronic circuit building to adapt to having less than 8 cylinders.
Google this
connect analog tachometer to prius engine
The Following User Says Thank You to Galane For This Useful Post:
09-21-2017, 02:18 PM
#457 (permalink)
Since it's more of an efficiency-oriented project, I wonder if some sort of analog "economy gauge" similar to what had been fitted to some Brazilian Fiats wouldn't match better this project.
09-21-2017, 07:45 PM
#458 (permalink)
A few questions:
When is your b-day?
My birthday was yesterday, Sept 20. (I turned 60)
Nope, they're gone. I will be using the factory Pontiac outside mirrors in their original location.
The hood tach has no purpose, and my wife thinks it's ugly. It won't be there in the future.
Bill the Engineer
09-21-2017, 07:48 PM
#459 (permalink)
The Economy gauge is just a vacuum gauge, which would be at zero as often as the tach would be. Anyway, my wife still thinks that the hood tach is ugly, so it's gone.
Bill the Engineer
09-21-2017, 08:30 PM
#460 (permalink)
Thalmaturge
Bill the Engineer
But how cool would it be to take the OBDII data, convert it to whatever drives the gauge (probably pulses/sec?) and make 0-8000 rpms into 0-80 mpg? Analog gauges are just so much more... visceral.
I've been thinking of getting a couple of these 3" panel meters and using the output from my OBDIIC&C (serial data stream) and an Arduino to make an analog state of charge and assist/regen amp display for my Insight.
https://www.surplussales.com/Meters/MtrDCMA.html
Sam
