Old 05-27-2015, 08:31 AM   #1 (permalink)
Needs More Duct Tape
MPGomatic's Avatar
Slambo - '99 Honda Civic HX
90 day: 44.21 mpg (US)
Fixing the Honda Civic's Parachute Problem with a Rear Belly Pan
I've been crawling around underneath Slambo, with the hope of smoothing out the tail. Started cutting up some cardboard this week, went a little nuts with the fiberglass.
Stage One:
First Test Fit:
I will try fastening it to the bumper with knockoff/OEM body panel clips (with a little duct tape insurance). Not sure where/how to fasten the front to the trunk floor. There's one spot that looks prime for drilling. Need to get Slambo up on ramps (better yet, a lift) to find additional fastening points.
Resin is a LOT less expensive if you buy it at big box home improvement stores, rather than auto part supply chain stores.
The Following 4 Users Say Thank You to MPGomatic For This Useful Post:
aerohead (05-27-2015), BabyDiesel (05-29-2015), BamZipPow (05-27-2015), rumdog (05-27-2015)
Old 05-27-2015, 09:54 AM   #2 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
try to run a cross brace, anchored at both ends, of aluminum, to attach it to.
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
The Following User Says Thank You to deejaaa For This Useful Post:
MPGomatic (05-27-2015)
Old 05-27-2015, 01:23 PM   #3 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Thank you for that friendly tip!
Old 05-28-2015, 09:18 PM   #4 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Stating the obvious here, but when you get to drilling the 'pan in place, it is really easy to overlook the gas tank and screw right into it.
I came pretty close to doing that myself.
Yikes !
I used self tapping metal screws to screw right into the frame of the car.
The Following User Says Thank You to Cd For This Useful Post:
MPGomatic (05-29-2015)
Old 05-29-2015, 07:42 AM   #5 (permalink)
MPGomatic's Avatar
Yikes !
Aye, yup! Fear of drilling into the gas tank =
This panel will start behind the control arms. I'm digging deejaa's cross brace idea.
Ain't Fuelin' - The Beater Build Show :
https://www.youtube.com/playlist?lis...R754kIg_V8Aahm
