05-11-2018, 05:04 PM
#11 (permalink)
With my car lowered it shouldn’t take all that much filler to skirt the edges of my front tires, but I’m not likely gonna mod my fenders yet
My current Ecotec project...
My last Ecotec project...
05-11-2018, 06:02 PM
#12 (permalink)
Where does one find one of these "loving wives?"
05-11-2018, 06:21 PM
#13 (permalink)
I got lucky finding mine, but they’re normally about as common as an automatic transmission VX
05-12-2018, 04:44 AM
#14 (permalink)
One could line the brushes with thin plastic foil.
I'd like to tilt the brushes forward to create a splitter like lip.
05-12-2018, 09:10 AM
#15 (permalink)
Toby - '13 Toyota Prius C 90 day: 61.95 mpg (US) Daz - '15 Mazda 3 iTouring w/ Tech Package 90 day: 38.2 mpg (US)
Originally Posted by 19bonestock88
...about as common as an automatic transmission vx
Lols
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
05-12-2018, 11:55 AM
#16 (permalink)
At freeway speeds, lawn edging is thin plastic foil.
05-12-2018, 05:46 PM
#17 (permalink)
I don’t see any backing short of coroplast or lawn edging adequately reinforcing the brush seal at highway speed... that being said, it could maybe so for filling wheel gap or such
05-25-2018, 12:40 AM
#18 (permalink)
lawn edging is worse than useless
when i see these threads discussing the use of lawn edging as air dams
i know the poster is "lacking in candor"
have tried and destroyed lawn edging air damns more than a few times
use a tire tread or two for wide applications , on the geo metro a 185 60 15 re 92 with both side walls sliced off to the edge of the steel belts is about
perfect
it will scrape sometimes but it will never break or crack or split or bend out of the way
unlike
the
useless
lawn edging
which will do all of the above in the first 30 days of use
05-25-2018, 12:57 AM
#19 (permalink)
Cyborg ECU
On mine, I used the curve of the edging itself and the ball end down to increase the rigidity in the airflow. I am sure it does not flex as you theorize. I know because I cannot move it aside to get a Jack under the car unless I use significant force.
perfect
unlike
the
useless
lawn edging
While I have replaced the edging once and had to improve the mounting a couple times, I have seven years of experience across 80,000 miles that suggests it's not useless as you assert. I think it matters how you mount it. I have not had to redo it in a few years now. It scrapes sometimes. Stays in place.
05-25-2018, 04:20 AM
#20 (permalink)
useless lawn edging ............
I had to drive around for a while with foil tape all over my old lawn edging chin spoiler because some a-hole could not parallel park.
Conveyor belt material is expensive, but you do it once and never have to mess with it again.
What sort of tools do you use to safely cut up an old tire with?
Power tools?
Hand, ear and eye protection?
If I ever do this I want to do it right and not end up in the hospital.
