Register
Now
Reply
Old 07-14-2008, 12:15 PM   #41 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Send a message via AIM to Chris D.
Originally Posted by Peakster View Post
You know I was just curious :
hmmm makes me think about trying this..
Old 07-14-2008, 03:34 PM   #42 (permalink)
This is some cool software!
Uploaded a 2009 Ford Escape Hybrid to my youtube.
Old 07-14-2008, 05:41 PM   #43 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.02 mpg (US)
Wow, this program is nice. I knew my car had bad drag but wow... was it really this bad? Yikes!
I'll have to look into that floating parallel spoiler idea.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 07-14-2008, 06:30 PM   #44 (permalink)
texanidiot25's Avatar
SlowBird - '90 Firebird
90 day: 13.46 mpg (US)
Originally Posted by i_am_socket View Post
I'm getting some interesting movies using the high Re numbers.
I get a lot of this:
using 2,500,000. Is it supposed to look like that?
Lower the Dt number to around .01, it seems to spaz out with higher Dt numbers. Real psychodelic stuff.
1990 Pontiac Firebird
3.1L V6, 4 speed auto, 270,000 miles and T-Tops!
Just finished getting it back on the road and in my hands for the 1st time.
Old 07-14-2008, 06:39 PM   #45 (permalink)
adrive7's Avatar
Ranger - '08 Ranger XL
90 day: 22.99 mpg (US)
Cobalt - '05 Cobalt LS
Zuma - '99 Zuma II
Send a message via AIM to adrive7
I would try adding white area all around the vehicle. Also, get rid of the tires so you can see the air flow under the car. If you increased the time step (dt) take it back down to around .01. It looks like you are seeing effects from the edges of the pictures, but I don't know why it would do that. Adding white area around it should get rid of that problem (if thats what it is)
The Reynolds number is fine.
Ohio State Baja SAE
Old 07-14-2008, 07:16 PM   #46 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 Wagon SW2
90 day: 42.91 mpg (US)
adrive7 -
I agree. In my runs, I added a "road" below my "hover-car" and I put some empty space behind the car to analyze the wake that my mods created.
If you put the tires on, I think it is like having "Flintstone Roller" tires, because you are cutting off airflow below the vehicle. I *think* if you want to approximate tires, you could add shallow "bumps" where the tires are. Maybe the compromise is to approximate how much "area" the tires displace below the car and make the "bump" proportional to that. Does that make sense?
I used an Re of 2,500,000 in my second analysis, and I set it to 40 seconds. I also used a 2-bit Bitmap.
CarloSW2
American Solar Energy Society
Old 07-16-2008, 10:50 PM   #47 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
90 day: 34.81 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 23.21 mpg (US)
This is pretty cool, but I can't play the videos either. My computer at work is the only one with high speed internet and I can't install anything, at least right now. Could someone give me a hand with this one? I copied a side view (pre-airdam) into Autocad and traced around it, then solid filled it, so it was black on white. Wheels off should simulate airflow under the majority of the car.
Old 07-16-2008, 11:15 PM   #48 (permalink)
Hi All,
This is all very interesting. But its been commented elsewhere what is usabilty of the results? One thing to look at is the flow at the rear. If there is flow upward, then extending the cam back is the thing to do. And if the flow is downward, then doing a diffuser, with some rear belly-panning is the the thing to do. What one wants to do is make the flow go straght back without upward or downward velocity components.
Can somebody do a Prius without wheels ?
Old 07-16-2008, 11:35 PM   #49 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
Wagonman
Values I used:
Re = 2,500,000
dt = 0.01
length = 30 sec
cutoff level = 0
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 07-17-2008, 01:07 PM   #50 (permalink)
wagonman76's Avatar
Cool, thanks a bunch!
Old 07-17-2008, 02:33 PM   #51 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Taurus GL (Sedan)
90 day: 21.92 mpg (US)
where are you guys getting these bitmaps of your cars?
Old 07-17-2008, 03:26 PM   #52 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
We make our own bitmaps. Find an image, pop it into some image editing program and delete non-car (but make sure to preserve the ground level to simulate the tires height).
I've done my xA (haven't posted it) and was working on that Prius.
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 07-17-2008, 05:12 PM   #53 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
2008 Prius
Re = 2465148 (calculated for 55mph)
dt = 0.01
length = 30sec
cutoff level = 0
  • driving style
  • aerodynamics
  • tires
  • weight reduction
Old 07-17-2008, 06:58 PM   #54 (permalink)
Oden - '00 Frontier Crew Cab
90 day: 19.48 mpg (US)
Malinda - '03 Grand Cherokee Limited
90 day: 13.69 mpg (US)
Nerdcycle - '81 CM400E
90 day: 47.36 mpg (US)
One thing I'm noticing on these that they're going to be pretty inaccurate if you don't have a belly pan, since all your bitmaps have smooth bottoms.
Old 07-17-2008, 07:25 PM   #55 (permalink)
Pokémoderator
cfg83's Avatar
extragoode -
I did an approximation with some random "bumps" on the underside and didn't see much of a difference. I'll upload it later tonight so you can see.
CarloSW2
Old 07-17-2008, 08:58 PM   #56 (permalink)
Hi azrael...,
Ooops..
Old 07-17-2008, 09:03 PM   #57 (permalink)
Hi azrael...,
Thanks for the Prius model.
The flow off the top, and off the bottom look very balanced. Possibly there is more flow coming up from below, and going turbulent. My car always has a dirty rear window undeneath the hatch spoiler. That seems to support the model results. Possibly a linear difusser, and a shallow angle might help that.
The car has very poor flow out the wheel well vents. And the hatch fogs up easily, and takes along time to defog. So, this also supports that the flow from underneath the car is stalling.
Old 07-17-2008, 11:41 PM   #58 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
here is the areo CRX as it sits in its current state..
Old 07-17-2008, 11:58 PM   #59 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
So other than being interesting in a lava lamp sort of way, how do you interpret the video to determine what is a lower air resistance?
Less red is better?
Less movement (wave action) is better?
Both?
pedal power - 2 miles per pbj samwich
Old 07-18-2008, 12:23 AM   #60 (permalink)
Veggiedynamics
Im not positive but yes i think your right less red and less wavey the better
Reply
air dam, air flow, simulation, spoiler, wind tunnel
The Mechanism Behind Flow Separation LostCause Aerodynamics 45 05-03-2008 05:33 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
