Old 10-03-2017, 11:24 PM   #61 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by t vago View Post
Well, for starters, I apparently am the first to have documented this not-so-easy method, waaaaaay back in June 2010.
Details are here: Dakota-Durango: Does anyone here use fuel rail cooling?
I remember coming up with the idea to do something about fuel temperatures after dealing with yet another instance of heat-soaked lack of response. Somebody else in that thread actually mentioned feeding the two banks independently, as a possible way of equalizing fuel temperatures.
Apparently, Summit Racing now states they do not recommend the Twist-Tite stuff for fuel use. I therefore recommend fabricating the fuel hoses out of braided nylon hoses and hose ends.
I knew AIRRAM had insulated his fuel rails, but I didn't think about the advantages. My 07 has 4 O2 sensors and 2 cats (not sure if that's how your 00 is), so I am curious to see how just some insulating tape might change fuel economy...
Old 10-04-2017, 12:01 AM   #62 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by mazdamx640 View Post
I'm interested in putting 12 hole injectors on my 99 f150 4.6 I know the stock is 19lb but not sure on body or electrical connector any idea on what might work?
I can't find very many 12 hole injectors at all, and cannot find anything that flows 19 lb/hr. Nearest I can figure, your injector cross-references to a Bosch 0280150955. That is an EV1 single pintle design with a Jetronic connector.
You may still get some improvement in FE by switching from your existing EV1 injectors to EV6 injectors that have 4 holes. I found injectors that will probably work, and they are p/n 0280155709. However, they apparently are only found in Europe.
The Following User Says Thank You to t vago For This Useful Post:
mazdamx640 (10-04-2017)
Old 10-04-2017, 12:21 AM   #63 (permalink)
MPGuino Supporter
t vago's Avatar
Originally Posted by hat_man View Post
t vago.... How did you find a comprable fuel injector? I know this is a rather open ended vague question, but did you just find the parameters of your stock injectors and then check RockAuto one by one until you found what you wanted? I have wanted to do this swap on my Ranger for a long time but am completely uneducated on the technical stuff. I can turn a wrench really well, but don't want to make any mistakes in sizing. When I look on RockAuto I can't tell how many holes the injectors have. I still have the stock single hole ones so even a 4-hole would be an improvement. I would love more holes if possible. Also isn't there a diference in high impedance and low impedance injectors. Not sure which I have (low I think) but I'm sure they aren't compatible. Any insight you have would be great.
Thanks
Basically, I do a lot of searching. For instance, I figure that your Ford Ranger uses an injector with an EV1 design, has a Jetronic D electrical connector, uses a 2.4 ohm resistance injector, and is rated at 34 lb/hr at 43.5 psig. It appears to be a peak/hold design.
And... unfortunately, I can find no injectors that have even an EV6 4-hole design that also has this flow rate and this electrical resistance.
Old 10-04-2017, 07:55 PM   #64 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Jeep 4.0 runners report good improvements in older threads by going to 4 hole. However, 12 hole are available for the 4.0 now.
Old 10-05-2017, 01:17 PM   #65 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
I don't want to hijack the thread, BUT I'm trying to find 12 hole, high impedance, ev6 injectors somewhere north of 24lb/hour (260hp v6).
Any ideas?
Also, I found a chart that shows my 280-156-300's as both 24 and 34 lb/hr??
Stan Weiss' - Electronic Fuel Injector (EFI) Flow Data Table
Old 11-26-2017, 10:24 AM   #66 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
t vago.... With what little research I have done (and I mean little) I was under the impression I had 14lb injectors in the Ranger. Single hole and EV1. I was told at one time I could try the 19lb injectors without having to change anything and a giving the Ranger a few tanks to get acquainted with them. I see RA has 4 hole 14lb injectors and even that may be an improvement from my OE 1 hole design. As old as the truck is (almost 300k miles) I am looking for simple "bolt-on" type improvements at this point. Just trying to squeeze as much as I can out of her before I have to look for something different.
If nice guys finish last, are you willing to pay the price to finish first ?
Old 11-26-2017, 12:36 PM   #67 (permalink)
Not sure if it will help anyone but I found this earlier today. It has some flow rates and other info.
Injector-Rehab Fuel Injector Cleaning Services
