Old 12-01-2015, 05:53 AM   #11 (permalink)
Originally Posted by Cd View Post
I had a similar problem. It turned out to be the ECU.
When you turn the key to the second click, ( just before the starter kicks in ) do you hear a slight whirring noise ? ( it lasts for around 3-4 seconds )
This would be the fuel pump priming.
If the fuel pump is priming, then I would look at the ECU.
Good luck
I will check this today.
It primes so intermittently..
Old 12-01-2015, 05:54 AM   #12 (permalink)
Originally Posted by Old Mechanic View Post
Distributor?
regards
mech
It's possible.. getting spark, though
What would I look for?
Old 12-02-2015, 05:40 AM   #13 (permalink)
Maybe today will be sunnier and I can focus on it.
Old 12-02-2015, 08:59 AM   #14 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Aren't Hondas of that era known for a solder joint going bad causing the fuel pump relay (under the dash) to not work?
I think it's called the "main relay"
Old 12-02-2015, 10:23 AM   #15 (permalink)
They are. I have a new relay in place.
Also, this is one of the reasons I won't leave BITOG alone: the knowledge base there. My goal is to sneak on, and be accepted, in time.
Old 12-02-2015, 01:45 PM   #16 (permalink)
Ok... Sling Blade hello.. The problem was a cominbation of:
1. Improper Firing Order (see videos)
2. No ground (ground is on it now)
And.. 3. NO GAS.
Watch my YouTube in the next hour for this awesomeness.... TheJCorbi82...
And stays running....
Old 12-02-2015, 01:59 PM   #17 (permalink)
Miller GET THIS ON BITOG...
Old 12-02-2015, 09:23 PM   #18 (permalink)
Miller88, this is for you.
Please put on BITOG somehow, maybe in the "I have to put this head on myself" update.
Old 12-02-2015, 10:29 PM   #19 (permalink)
fuse, power to the pump (read at the pump itself), relay energization circuit (need a wiring diagram).
bad relay
bad pump
bad ignition switch
bad ground
wiring defect in the circuit
no gas
fuel tank pickup damaged or bent where it will not pick up fuel
regards
mech
looks like I pegged it.
bad ground
no gas
still don't understand your response to that post but glad to see you got it running
regards
mech
Old 12-03-2015, 08:19 PM   #20 (permalink)
The Following User Says Thank You to GearheadTool For This Useful Post:
Cd (12-03-2015)
