Old 06-26-2015, 05:11 AM   #1 (permalink)
Getting started with MPGuino. Need help with weird display.
Arduino uno, spark fun LCD, v0.86 (not sure what info you'll need to know).
Anyway I've been troubleshooting display issues and haven't gotten far. After power cycles, different editions of code, and double checking wiring, my display shows "Contrast, 000000000055 OK XX" and the LCD backlight and led from the transistor occasionally turn off and on. I can't make it change screens or anything with the buttons. What do I need to do? Thanks in advance!
Old 07-06-2015, 07:36 AM   #2 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Hi,
That's a strange issue...
Let me know what diagram exactly have you used to build your MPGuino - there are few of these... Maybe some photos of the setup?
I'll do my best to help you.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 07-06-2015, 07:54 AM   #3 (permalink)
Thanks for the response! I actually got the main issue figured out: my buttons were connected sideways so they were effectively always closed. I still have an issue with the backlight. Changing the brightness doesn't help. It comes on after about 30 seconds and only stays on for a second. It's not a constant interval between blinks. I used the Arduino assembly schematic on the wiki.
Old 07-06-2015, 09:49 AM   #4 (permalink)
AndrzejM's Avatar
It seems that there's something wrong with transistor running current to the backlight.
It's easy to chech if you'll connect LED backlight with 330 ohm resistor to +5V it should be stable. If not it means that there's something wrong with your LCD display. If everything will be ok with resistor, there's something wrong with connection between Arduino and LCD. There's resistor, and transistor only so not hard to find the reason.
And one more question - are you sure that you connected backlight signal to digital 9 ?
