Register
Now
Reply
Old 10-01-2008, 03:55 PM   #21 (permalink)
Here is a guys site that I had bookmarked from quite a while ago. He has cut apart a lot of filters but I am not sure how up to date it is.
Engine Oil Filters
Old 10-01-2008, 05:52 PM   #22 (permalink)
Engine Oil Filters
It's tagged at the bottom as 1999.
not that current,
but good info anyway.
Old 10-01-2008, 06:24 PM   #23 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
90 day: 54.79 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Just wanted to make sure that everybody had been to Bob is the oil guy forums.
Bob Is The Oil Guy - Powered by Motor Oil
Specifically Bob Is The Oil Guy - Powered by Motor Oil
Oh; and since I'm getting K&N filter adds in this thread, Filtration Testing for Amsoil, K&N, Napa, Jackson Racing, Baldwin, and Mazda air filters on a Miata Not the worst; but close.
Old 10-02-2008, 02:28 PM   #24 (permalink)
the firefly - '91 Firefly Base
Last 3: 50.5 mpg (US)
White Lighting - '94 Civic HB VX
90 day: 48.65 mpg (US)
Bob is The Oil Guy is a WEALTH of info on this subject.
Carquest Blue Brand Filters (Wix) on my VX and any other vehicles I happen to procure, as the guys at BITOG have said time and time again Wix makes the best cheap filter, Purolator being the best at more $$ but much cheaper than an AMSOIL filter.
Another piece of the puzzle to consider is the Bypass valve which on some filters is complete junk and can cause the filter to bypass oil before it is even close to being clogged.
Old 10-08-2008, 08:44 PM   #25 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Civic Sedan LX
90 day: 38.07 mpg (US)
Thumbs up
Yes, BITOG
For another $4-6 per year, I can treat my car to a much better oil filter. This is something that more reliably keeps bits of metal out of critical areas and is less likely to give me a dry start on a cold morning.
They are well worth it.
Also, for what is some of the shoddiest workmanship in an automotive product, Fram filters are NOT the cheapest. Supertech (made by Chmpion Labs) are better. Purolator are better still but Wix, Baldwin, Hastings and a few of the OEMs are my favorites.
For those of you skimping on oil changes, the coefficient of friction of the oil goes up as contaminants accumulate and the additive package becomes depleted. As friction goes up, heat and drag increases ... reducing efficiency. The pennies you save will cost you over the road.
I'm with The Mullet. Change your oil and use good supplies when you do.
--- Bror Jace
Old 10-08-2008, 09:04 PM   #26 (permalink)
Moderator
tasdrouille's Avatar
The Truck (mine) - '99 A3 Jetta TDI
90 day: 62.27 mpg (US)
The Guzzler (hers) - '08 Elantra GL
90 day: 34.66 mpg (US)
Sorry to steer the thread in an other direction, but I'd just like to mention a way to know if you need to change your oil (appart from an oil analysis).
All you need is an oil pressure gauge and oil temp gauge.
When you change your oil with fresh oil, record the pressure at idle for a given temperature (fully warmed engine).
Later in time, as long as the pressure at the same rpm and temperature remains the same you don't need to change your oil.
As Bror mentionned, as the oil age, accumulate dirt and contaminants and additives get depleted, the viscosity of the oil will change. You can detect the change of viscosity by monitoring the pressure of the oil under the same flow (rpm) and temperature.
Old 10-08-2008, 09:16 PM   #27 (permalink)
Yeek! I wouldn't let it go that far. In my view, when the oil can't keep up its viscosity, it is really well and truly dead dead dead! And probably should have been changed a while ago.
I also don't feel that a combination of oil temp and pressure readings off of (fallible) gauges is an accurate enough method to assess the condition of the oil. And getting it wrong can be quite expensive...
Then again, I come from the air-cooled world, and we tend to be really (over?) zealous about changing our oil.
-soD
Old 10-08-2008, 10:22 PM   #28 (permalink)
I wonder how the GM oil change monitor system decides when to tell you it is time to change? Maybe they just detect the pressure and temp to a given table of values ?
Old 10-08-2008, 11:12 PM   #29 (permalink)
(milis()/10000)%6
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Yes, friction goes up as contaminates accumulate and additive packages deplete... But to say my long oil change interval = accumulated bits and depleted additive packages is a fallacy.
Every oil change, I send a sample to a lab for testing. I can tell you, with certainty, my contaminates are low*, insolubles are low (filter is filtering ), viscosity is within acceptable limits, and TBN has always been above 6.0
*except for copper - 2000 VW 2.0 engine had their piston rings installed upside down from the factory (piston ring mfr started stamping their label on the bottom rather than the top as they did prior: as a result, a chamfer isn't where it's supposed to be) - so occasionally copper wear is a little higher than it should be, but not by much.
My best tank to date was on oil with over 9K miles (that's conventional oil too ). Yes, that's anecdotal - I'm just throwing that out there
Challenge me, or correct me, but don't ask me to die quietly.
Old 10-08-2008, 11:22 PM   #30 (permalink)
(milis()/10000)%6
Not entirely sure how GM does it - a friend once explained to me that it's based on starts/stops, miles, etc. etc. and thrown into an algorithm. If that's the case, you'll probably have to trust that GM got it right AND that they're not short selling you (outside of a reasonable safety factor).
But BMW, from whatever article it was that I read, uses "electrical properties" (resistance?) of oil which change as the oil wears out.
Not sure how effective it is....
Old 10-09-2008, 07:44 AM   #31 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
Yes, the oil life monitors (OLMs) use a fairly sophisticated algorithm to monitor the amount of wear on an oil from a variety of inputs including number of stops and starts, length of trips, total miles, maybe even ambient temps during the interval. Ahead of time they project what effect that will have on wear (they don't adjust for the type of oil you use, obviously) and try to get people to change their oil before a significant amount of damage is done.
I once saw a Civic owner that ran is oil until the minute the OLM said 0% ... he then changed the oil and sent the sample away for a UOA. The oil was completely shot and there were blatant signs of increased wear.
So, they are a tool ... and like a lot of tools in our everyday lives, they are dumbed down to the lowest common denominator. Following them is not necessarily the smartest way to go. Keep this in mind when looking at the OLM.
And no UOA I've ever seen is able to measure the coefficient of friction of oils. I've seen some manufacturer testing (I think it was from Red Line) and I was aghast at the drop across the board among all brands ... and the oils were not in use all that long.
Interesting about BMW using electrical properties. I'm not sure what conductivity oil has (I'm assumin it's poor) but it does make sense that as it accumulates moisture and acids, that value would change (increase) and that seems like a pretty good input as to the condition of the oil for an OLM.
Of course, I think that by this time the oil is well on its way to being shot so I'd want to change it before those properties change enough to register (of course I'm just guessing about the meter's sensitivity).
Because I travel about 9,000-10,000 miles per year and don't want to have to change my oil in the middle of winter, I end up changing my oil every 3,500 miles or so. Even if I went up to 15,000+ miles per year (which is what I used to do) I'd probably keep the same schedule.
For a lot of short trips (12-15 minute commute one way) that isn't too excessive and I diligently take my oil back for recycling, of course.
--- Bror Jace
Old 10-09-2008, 09:49 AM   #32 (permalink)
(milis()/10000)%6
Viscosity is a measure of fluid resistance, which can be thought of as friction In any case (as internal resistance isn't what you're talking about ), friction coefficients are not the metric used (at least in the report's I've received) to determine when a oil starts to become abrasive, actually knowing these values would be purely academic.
Really, I don't see how one would measure the friction coefficient - that's going to be dependent on the individual parts (materials, surface condition, etc.) and their load conditions on top of the state of the oil. I guess one could make a standardized test, but those figures would again, be purely academic and, in this case, not directly applicable (compared to metrics such as TBN, insolubles, elemental makeup, etc.).
Old 10-09-2008, 08:50 PM   #33 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
Trebuchet03, the resistance to a heavier fluid is hydrodynamic drag. Since the engine parts push the oil out of the way as it turns, the heavier (greater resistance to flow) the oil, the greater resistance for the engine ... otherwise known as higher load.
Coefficient of friction is different. They must use fluids of equal weight (cSt - centistrokes) and then rub one surface against another (say, a small polished metal plate against a larger flat surface) and then measure the resistance.
That's just a guess ... but some SAE-type tests are actually that simple. Ever see a Timken bearing machine used in oil tests?
--- Bror Jace
Old 10-10-2008, 10:50 AM   #34 (permalink)
(milis()/10000)%6
That's all well and good - but I stand by my original statement
...friction goes up as contaminates accumulate and additive packages deplete... But to say my long oil change interval = accumulated bits and depleted additive packages is a fallacy.
As for the timken OK load test machine - yes, there's one (well, probably more than one that I'm unaware of) @ my school's shop. But, it's a qualitative-relative test. I'd get slapped (and/or, a good talking to ) if I reported the results at face value rather than comparing one sample to another one. There are much better quantitative-discrete tests which are used
Old 10-10-2008, 07:49 PM   #35 (permalink)
This is why all manufacturers have switched to 5w20 weight oil as the lower engine load improves fuel economy which inturn makes a manufacturers average fuel efficiency for all vehicles produced higher.
Old 10-10-2008, 08:11 PM   #36 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
Yes flydude, that is correct. The thinner oils are almost always introduced to save fuel. Funny thing is, 5W-20 oils also protect as well as 5W-30 oils (proven by UOAs).
Trebuchet03, you implied above that viscosity = friction. I was trying to separate the two. I'm sorry if I was not clear.
--- Bror Jace
Old 10-10-2008, 10:45 PM   #37 (permalink)
I did not think that a 5w20 would protect as well as a 5w30. Interesting, perhaps I will run some 5w20 in my vx.
Old 10-11-2008, 02:59 PM   #38 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
Yes, using a thinner (not necessarily synthetic) oil (5W-20, 0W-20, etc ...) will provide less drag/resistance and possibly improve fuel economy by a measurable amount.
Most cars that currently spec 5W-20 were designed with 5W-30 in mind. So, it stands to reason that many engines that currently spec 5W-30 can be switched over with no adverse effects ... just a slight increase (0.25 - 0.50) in measured fuel economy. If you search the UOA section of BITOG, you can find others that have already gone this route and had a sample tested for signs of increased wear. I haven't seen all these results, but I have yet
There are two other factors that make me comfortable with this idea:
1) With any interval past 3,000 miles, most XW-30 oils shear down to a XW-20 anyway. With the extended intervals recommended by most manufacturers these days, many engines are operating with a 20 weight oil in the sump.
2) When some manufacturers (Ford and Honda come to mind) switched over to 5W-20, they made sure the oils were made with more Group II+ or Group III base stocks for added stability and they increased the barrier anti-wear additives such as moly and boron. UOAs of these 5W-20s show this clearly.
Now that ZDDP levels in SJ, SL, SM oils are lower than their predecessors, the blenders have discovered that adding moly and/or boron can make a very high-performance, low-wear oil.
--- Bror Jace
Reply
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 44 10-19-2008 01:04 AM
Debate continues: K&N filter vs. MPG DifferentPointofView EcoModding Central 25 10-10-2008 08:33 PM
The Great Charging Debate! Christopher Jordan Fossil Fuel Free 5 09-26-2008 07:34 PM
Larger oil filter for better FE? Gregte DIY / How-to 19 07-27-2008 07:25 PM
Air filter saunders1313 Hypermiling / EcoDriver's Ed 11 07-26-2008 12:25 AM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
