Old 04-04-2017, 04:44 AM   #11 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
"Replace the 12V battery or charge it up and disconnect the three connectors on the BCM(circled in red). This will force your DC-DC converter to stay on. Then you can drive the car without worry and we'll help you work through the problems."
Thoughts?
I drove mine around with the IMA battery turned off for months, I just clicked off the big battery switch in back. You definitely need a good 12V battery though, and that only works if it was just your IMA battery going bad, not if the BCM is bad too
Old 04-04-2017, 08:36 AM   #12 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
This is your excuse to build a LiFePO4 plugin pack for the 12 volt system.
If you get your IMA running again, you can even make a 12v to 112v(?) booster circuit to maximise the use of electricity on shorter trips.
