Old 01-22-2017, 06:06 AM   #41 (permalink)
gil
gil's Avatar
The Drift - '85 Toyota Corolla GTS
90 day: 28.26 mpg (US)
!Rally - '02 Subaru Impreza WRX
90 day: 27.68 mpg (US)
Cinnamon - '13 Honda PCX 150
90 day: 75.86 mpg (US)
Originally Posted by Dean in Milwaukee View Post
I made these coroplast cutouts to help block the cold wind on my 2013 pcx, and they work quite well, removing buffeting and making a dead air zone on my lower body except for my feet. No more cold legs!
They are held on by having a tight fitting hole over the turn signal and some clear tape to seal them to the bodywork.
They work well enough that my effective riding season is extended, and cost under $10 to make from coroplast I got from home depot.
I had something like that for my helix but made of plexiglass. I might just try that on my pcx. On a side note, I like your hand guards. I saw those on eBay, but didn't think they would fit. How do you like them?
Gil
Old 02-06-2017, 09:53 PM   #42 (permalink)
I do like them but wish they were bigger, and they required a fair bit of trimming to fit.
Old 04-04-2017, 12:41 AM   #43 (permalink)
15 Civic - '15 Honda Civic Sedan EX
Sendler, could you please share your modifications to the stock exhaust? Also, any ill effects on exhaust longevity as its been a couple of years? Thanks!
Old 04-04-2017, 06:18 AM   #44 (permalink)
sendler's Avatar
90 day: 105.14 mpg (US)
90 day: 60.68 mpg (US)
90 day: 38.51 mpg (US)
PCX153 - '13 Honda PCX150
90 day: 104.48 mpg (US)
90 day: 80.94 mpg (US)
90 day: 72.57 mpg (US)
There has been no change in the longevity if the pipe. I have 20,000 miles now. I took me a few tries to find the right spot. Just drill a hole which lets the gas out after the cat but before the long skinny pipe. Measure back from the weld and drill up at a 45 degree angle so you don't even have to remove the pipe. Mine got a bit loud at full throttle so I would go with a slightly smaller hole.
The Following User Says Thank You to sendler For This Useful Post:
ScottDR (04-04-2017)
Old 04-04-2017, 07:29 AM   #45 (permalink)
Terrific, thank you for your help! And super fast reply!
Cheers!
Old 04-15-2017, 06:51 AM   #46 (permalink)
Sendler, just to clarify...you posted above to drill at a 45 degree angle. Was that 45 degree as from the passenger side? Or 45 degree from bike front to back? Also, is that the catalytic converter seen through the hole? If so I better be careful not to let the bit impact that. Thanks again in advance.
Scott
Old 04-15-2017, 07:14 AM   #47 (permalink)
sendler's Avatar
I wanted the hole down and away from the bike so that is the angle with the ground. The pipe for the cat is just inside the outer can so stop drilling when you break through. There are some brackets that I encountered with the first couple test holes that aren't pictured in the cutaway photo so that is why I have included the measurement photo.
ScottDR (04-15-2017)
Old 08-05-2018, 08:17 AM   #48 (permalink)
Sendler, my apologies. I didn't save your pictures and now can't view them. If memory serves the hole was 5" from the front weld on the muffler, correct?
Old 08-05-2018, 08:56 AM   #49 (permalink)
sendler's Avatar
3 inches from the outlet weld at a 45* angle from the bottom. Use slightly less area than I did as it is a bit loud on full throttle.
ScottDR (08-05-2018)
Old 08-05-2018, 02:19 PM   #50 (permalink)
Thanks again!
