Register
Now
Reply
Old 08-19-2008, 05:39 PM   #21 (permalink)
I REFUSE!
thebrad's Avatar
VTEC Express - '96 Civic CX
90 day: 57.72 mpg (US)
Send a message via AIM to thebrad
Originally Posted by Vince-HX View Post
A tuner informed me that honda's dont go into open loop unless throttle is over 90% and rpms are high enough.
I accel @ 0-1 in vacuum (about 75%) and always pulse from 1500-2000 rpm. This has given me high 60's in city driving.
Ha, I shift at 1500.
Old 08-19-2008, 05:42 PM   #22 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 45.63 mpg (US)
Daox's Matrix - '03 Matrix
90 day: 38.97 mpg (US)
Shifting sooner is not necessarily better. It depends on the engine. Most engines are more fuel efficient around 2500 rpm.
EcoRenovator.org - Efficient living and green home improvement
Matrix Build Thread
Paseo Build Thread
Old 08-19-2008, 05:43 PM   #23 (permalink)
hypermiling lobsta
Vince- i was hoping to hear from you, there was a post recently on ht where you had talked about your experiences and then seeing your employment with full race had the wheels turning wondering if you and the guys there had any crazy new parts that you have fabricated. I also seem to be folowing your recipe for my acceleration as well with the pulse and glide, sadly i don't regularly commute in my hatch so i haven't been able to hone my skills on a daily basis
Old 08-19-2008, 05:45 PM   #24 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
90 day: 50.49 mpg (US)
based on that most efficient mean piston speed formula my optimal shift points are between 2000-2500.
2000 works for me, I still have a pretty good accel rate and that style of driving corresponds pretty well with my factory shift light.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-19-2008, 05:46 PM   #25 (permalink)
I REFUSE!
thebrad's Avatar
It's pretty much ingrained in the way I drive, plus it lines up with the shift values recommended in the owners manual.
Old 08-19-2008, 05:51 PM   #26 (permalink)
Vince-HX's Avatar
EJ7 - '96 civic Hx
We always have crazy new parts and ideas
Its great working @ a fab shop like Full Race. I have access to some of the best tooling available and some of the smartest engineers I know. The best part is that the bossman is all for trying out new ideas and combining power with FE. I'm very lucky to say the least.
And trust me, ideas are flowing
here is a little teaser - Ive made a device that has low 50 degree output temps without the use of a AC compressor
www.full-race.com
Old 08-19-2008, 06:43 PM   #27 (permalink)
hypermiling lobsta
well seeing the quality of work and your somewhat seemingly quick results speak for themselves which pair that with you have a civic very similar to mine makes me follow most of the stuff that you are doing. And any new stuff you need a guinea pig for or someone to do trial and error with im all for it. Im trying to understand more of the science behind how our motors work but its hard to keep up sometimes.
I will say keep up the awesome work , and let me know when you get the contraption for cooling ready i want a piece of that!
Old 08-19-2008, 07:17 PM   #28 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 54 mpg (US)
I aim to always (regardless of speed) accelerate at around 80% load
What do you mean by 80% load? I am just learning on this. How do you figure load %'s?
Old 08-19-2008, 07:56 PM   #29 (permalink)
Moderator
tasdrouille's Avatar
The Truck (mine) - '99 A3 Jetta TDI
90 day: 62.27 mpg (US)
The Guzzler (hers) - '08 Elantra GL
90 day: 34.66 mpg (US)
You get it from the scangauge. AFAIK it's the percentage of total available power (or is it torque?) for any given rpm you are currently using. Imagine the power curve in your head, the load is where you are in relation to the power curve (which is 100%).
Old 08-19-2008, 07:58 PM   #30 (permalink)
hypermiling lobsta
which as posted above pretty means where you are closest to your optimum bsfc, i think thats correct. Also you can find out the load on you engine with a scangauge or using a vaccuum gauge
Old 08-19-2008, 08:58 PM   #31 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 xA
90 day: 42.02 mpg (US)
Yep, BSFC map is your friend in visualizing it.
I couldn't find one for my own car but I know there was a topic about them here. This is an article from Autospeed about them with a few example maps:
Brake Specific Fuel Consumption
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
Old 08-19-2008, 10:01 PM   #32 (permalink)
badaz907's Avatar
dg - '99 civic ex
90 day: 32.96 mpg (US)
Send a message via AIM to badaz907
Question 1999 civic ex
I know I have the more powerful engine at 127hp vtec, but i find that while looking at my vacuum gauge the best vacuum occurs at 2500-3000 rpm, so you guys always talk about driving under 2k rpm but when i do in my civ vacuum remains low in or around 0-5 full throttle because it doesnt seem to have enough torque to move. what I'm asking is how to drive my civic in the city its a 5 speed so light throttle to get moving and coasting at 3000 to obatian best vacuum is this correct. I need a clear answer , most posts are a bit confusing please help.
Old 08-19-2008, 10:22 PM   #33 (permalink)
hypermiling lobsta
well most cars are different but most of us with one of the d16 varieties have seen the best results staying between 1500 and 2500 at most but someone like me has gotten best results shifting at 2000rpm that way you also can keep your speed down easier, you just need to see what does best for you accel and shift at 2k, 2500, or 3k and then report back. Since i have a scangauge i use engine load which i keep at about 75
Old 08-19-2008, 11:24 PM   #34 (permalink)
badaz907's Avatar
dg - '99 civic ex
a
I can use the vacuum to see engine load, basicly lower the vacuum the more throttle im giving it, I would get a scan gauge but I find that they are too costly, the vacuum gauge was 20 bucks however on this tank with the spoiler removed new dist, 40 psi in the tires and grill block i think i am currently getting 36-40 mpg city
Old 08-20-2008, 12:27 AM   #35 (permalink)
Addicted
bbjsw10's Avatar
90 day: 54 mpg (US)
I get roughly 18-20in. hg. at idle and accelerate at 10in. on vacuum gauge where would that fall in load %'s. Just to give me an idea, I tried reading the link posted but got lost over my head I guess.
Old 08-20-2008, 01:37 AM   #36 (permalink)
hypermiling lobsta
from what i have seen that you want too see the most amount of vac for the least amount of fuel used, higher vac means the throttle is closed hte most there for creating a vac in the intake manifold
Old 08-20-2008, 02:04 AM   #37 (permalink)
Vince-HX's Avatar
EJ7 - '96 civic Hx
Minimize pumping losses while accelerating.
Accel - least amount of vac without going into open loop
Cruise - highest amount of vacuum @ efficient rpm
imo
www.full-race.com
Old 08-20-2008, 11:17 AM   #38 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 62.28 mpg (US)
I like to accelerate at about 50% throttle at lower speeds, working up to about 80% at higher speeds and gears. Something like this:
1st gear: just to get moving. Shift before 5mph.
2nd gear: 50% throttle
3rd: 60% throttle
4th: 70% throttle
5th: 80% throttle pulse, then glide, then pulse again
Watching the scangauge, these throttle points roughly correlate to 70-80% load in each gear. At low speed and rpm, there's less power available, so it takes less throttle to reach the same load %.
80% load is about 12 on the MAP gauge, so near WOT but not quite there. I find that my Honda will go to Open Loop at about 90% load.
- - - - -Best 8-mile commute: 74.8 mpg
- - - - -Best tank: 66.6 mpg / 730 miles
Old 08-20-2008, 08:51 PM   #39 (permalink)
sickpuppy318's Avatar
the mazda - '01 Protege LX
90 day: 34.68 mpg (US)
imo
wow, thanks for putting it so simply
And i think i'd take your oppinion anyday because for a while there i was a tuner mag junkie and always loved the full race stuff. I don't generally "like" hondas but, well, you know, you work there.
i dont have any instrumentation (gauge cluster doesn't even work), but just driving my three speed tercel to work today with that little tidbit in the back of my mind, i think i've "modded" my technique for the better.
thanks for the insight.
Call channel five, get them broads over here, tell them of the tragedy of my trappedness.
Old 08-20-2008, 09:30 PM   #40 (permalink)
hypermiling lobsta
so in watching lod on the scangauge you want 70-80% of the maximum out of your engine therefore keeping it in its maximum bsfc atleast that is where it would be for the honda guys here with the 1.6l engines
Reply
100+ hypermiling / ecodriving tips & tactics MetroMPG Hypermiling / EcoDriver's Ed 155 10-29-2008 11:58 PM
Holistic Hypermiling LostCause Hypermiling / EcoDriver's Ed 8 04-30-2008 11:35 PM
Accelerating and shift points bhazard Hypermiling / EcoDriver's Ed 26 04-25-2008 05:52 PM
Rolling hills... whats the best way to drive them? hondaworkshop Hypermiling / EcoDriver's Ed 7 02-19-2008 03:49 PM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
