Old 07-13-2017, 12:10 PM   #1 (permalink)
How accurate is a Scangauge 2 for MPG?
My Scangauge 2 shows that my dark blue 2005 Civic gets reduced mileage when going up hills or accelerating, and increased mileage when going down hill or stopping. That makes sense. What does NOT make sense is that the MPG is highest at around 60-70 MPH. Should I just drive the speed that it reports the best mileage where legal and safe? A friend said that I should believe my Scangauge because my car will get its best mileage at higher speeds because, unlike his truck, my car is aerodynamic, so it is more efficient at a higher speed. That sort of makes sense. Is he right? Thanks, I want to save fuel by driving fast if possible
Old 07-13-2017, 12:23 PM   #2 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
It's accurate once it's calibrated, but it's relatively accurate even before that- higher numbers, whether or not they're "real" are higher than lower numbers.
Gearing can leave the engine at its most efficient spot, and steady cruising doesn't put too much load on an engine, especially on something aerodynamic. My Fit does best between 40 an 50 mph because it's a brick.
Calibrate it at every fill up for a while, and the numbers will get more accurate and you'll be able to believe the screen a lot more.
Transmission type Efficiency
The Following User Says Thank You to Fat Charlie For This Useful Post:
EcoCivic (07-13-2017)
Old 07-13-2017, 04:11 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Generally, on a level road your car will get its best mileage when it shifts into top gear.
(Is yours manual or automatic? Make a garage entry so your vehicle details are accessible under your username!)
The instantaneous readings are accurate once you've got it calibrated to your car.
Old 07-13-2017, 04:25 PM   #4 (permalink)
Thanks a lot! It has a 4 speed automatic transmission. Also, how do I calibrate my Scangauge? I bought it used and it did not come with the manual.
Old 07-13-2017, 04:28 PM   #5 (permalink)
When you fill, you go something like:
MORE > FILL UP
And it gives you the chance to enter or correct the volume of fuel you actually purchased in place of the volume of fuel the SG calculated you burned. You're adjusting a "fuel offset" which is applied to further calculations.
Note: You can also adjust a speed/odometer offset.
I'm sure you can still get the user manual from their site. Yup:
https://www.scangauge.com/support/user-manuals/
Old 07-14-2017, 12:54 PM   #6 (permalink)
My experience, comparing it against the Insight's built-in gauge, is that it's not even close.
Old 07-14-2017, 01:31 PM   #7 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
But which one is right?
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 07-14-2017, 01:46 PM   #8 (permalink)
That's mainly because the ScanGauge isn't designed for lean burn vehicles. It assumes 14.7 to 1 air/fuel ratio.
Old 07-14-2017, 09:18 PM   #9 (permalink)
Originally Posted by roosterk0031 View Post
Also of you change your fuel form E0 to E10 or E15 it needs to be recalibrated. The SG2 uses airflow to calculate fuel use and the more ethanol in the fuel the less air is needed to meet Stoich.
I wish I could get ethanol free fuel in Ohio. In North Carolina, I used to get ethanol free fuel from a Shell near work, but I can't find ethanol free fuel.
Old 07-17-2017, 10:04 AM   #10 (permalink)
Focused on MPG
Marinator - '06 Mercury Mariner Premier
90 day: 10.61 mpg (US)
SILVER BULLET - '19 DODGE GRAND CARAVAN GT
90 day: 18.41 mpg (US)
Myrtle - Wife's JKU - '12 Jeep JK Unlimited Sport
90 day: 15.7 mpg (US)
If looking for Ethanol free fuel in the states, try this site:
https://www.pure-gas.org/
Staying Focus'd on MPG
