10-28-2017, 09:25 AM
How long do your cell phone chargers last?
I bought one last night from Best Buy and it is already doing the Not Charging, Charging, Not Charging nonsense. I have been keeping them plugged in as much as possible, unplugging the other end when necessary, and carrying the cord with it, still plugged in. I have not unplugged this cord since purchasing it last night!
One roommate said his iPhone's chargers lasted him years, but I am pretty sure the longest any have lasted in my Android is a month. It is two and a half years old. I have considered replacing the charging port, but often when I fixed my laptop, something tiny and fragile broke. I don't want that happening with my phone!
10-28-2017, 09:27 AM
I have used wireless chargers, but the "fast charger" barely maintains my battery if I am actually using it, but after a couple of weeks they also started doing the Not Charging, Charging, Not Charging nonsense.
10-28-2017, 09:39 AM
My previous phone used to last about a week on its battery, but gradually it went down to less than a day - awkwardly, in lumps and with exceptions.
Then it started resetting itself for no reason.
Also the USB connector did not fit really nice anymore...
Long story short; dirt in the connector was shorting the power bearing contacts!
One good clean and it lasted a week again. Maybe that helps you too.
10-28-2017, 09:48 AM
A 2.5 year old phone? I would bet the battery is very near end of life (approaching 1000 cycles). And yes, dirt and corrosion will cause problems on the charging contacts, but you problem sounds like a loose wire or the charger is not powerful enough and the voltage is sagging under load so the phones charge controller shuts down.
10-28-2017, 10:13 AM
The cords last a year or 2.
I have not had a 120v to 5v USB power supply go bad.
If the phone turns off for no reason you probably have a bad battery.
10-28-2017, 10:14 AM
Dunno. Use my PC to charge most things.
Oh, wait...there's the tablets. They have AC USB chargers. They've been going for years. Occasionally have to replace a dead USB cable though.
10-28-2017, 10:16 AM
Permanent Lurker
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k) 90 day: 47.08 mpg (US)
Every one of my chargers outlasted their respective phones, and I never had problems with charging. I follow simple rules:
- never leave charger in AC outlet ( ?wall socket?) when not in use
- do not use (phone, walk, surf etc) while charging
- Plug and unplug softly, keep socket clean
- Full charge, full discharge
- do not bend cables
10-28-2017, 10:30 AM
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab 90 day: 20.98 mpg (US)
Mine last forever. The only thing I've noticed since I got an iPad is that the phone chargers won't charge it because it needs more oomph (that's tech jargon for amperage).
10-28-2017, 01:42 PM
#9 (permalink)
My life is un-troubled by such things, but in general —with consumer electronics— things tend to fail out of the box or at the end of life after a long stretch of reliability.
Your part hadn't achieved burn-in.
If it wasn't this way you wouldn't have received a warranty with it.
10-28-2017, 01:47 PM
#10 (permalink)
They always outlast the phone. Never had to replace an OEM one.
