Old 06-18-2018, 08:02 PM   #1 (permalink)
90 day: 29.44 mpg (US)
I secured a table saw, but it immediately smells like it is burning
It is a Makita 2703 15 Amp 10-Inch Benchtop Table Saw. Its replacement sells for $528 on Amazon. Is it worth diagnosing the problem and trying to fix it? Having a tablesaw would be extremely useful. I have a circular saw, but a tablesaw would save a great deal of time. I have seen people screwing circular saws to the bottom of tables to rig tablesaws, but an actual tablesaw would be much better. Harbor Freight's version is $140 and eventually I will be able to get it a bit cheaper.
I could always put up a notification for Craigslist, but it would be far easier to find a used one back in the Phoenix area, I just rarely drive down there.
What do you guys think?
Old 06-18-2018, 08:29 PM   #2 (permalink)
Make sure you're using a extension cord that's at least a 12/3 cord.
12/3 carries 15 amp. Anything less will shorten the saws life. (burn up)
Ryobi makes a decent Table Saw that is inexpensive.
No need to spend big bucks.
Old 06-18-2018, 08:50 PM   #3 (permalink)
Wood bring or motor burning?
Old 06-18-2018, 10:01 PM   #4 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
This. Lots of stuff burns.
Old 06-18-2018, 10:16 PM   #5 (permalink)
It immediately smells like it is burning. I did not try to bring wood or bring a motor.
Old 06-18-2018, 11:04 PM   #6 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
As soon as it is plugged in or after the motor is turned on? Did you try turning the blade to make sure it isn't stuck?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 06-18-2018, 11:31 PM   #7 (permalink)
As soon as I turned it on. The blade spins freely.
Old 06-19-2018, 01:40 AM   #8 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Assuming it has 'em, check the brushes.
Old 06-19-2018, 02:10 AM   #9 (permalink)
This page does not show brushes on the parts diagram, but owners mention it: https://www.ereplacementparts.com/ma...8_216_217.html
I will check it when I finish replacing my timing belt.
Old 06-19-2018, 05:04 AM   #10 (permalink)
If the rated RPM is higher than 3,600rpm it's going to have brushes.
