Old 04-04-2011, 03:02 PM   #51 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by dremd View Post
Torque limiting maps are pretty common on tuned turbo diesels.
Basically you limit fueling (and boost) to the max torque you think your driveline can handle.
Chrysler crippled the Liberty CRD with this technique rather than addressing the root cause, a poorly designed torque converter....
I'm not coasting, I'm shifting slowly.
Old 04-04-2011, 03:11 PM   #52 (permalink)
The PRC.
Quite a few generic remaps just move the torque limit around.
Conn.
I kind of think the 5.5/100km vs 5.6/100km is inside any margin of error IMHO.
Old 04-07-2017, 12:04 AM   #53 (permalink)
i bought a tdi mk4 golf that an idiot had modified to be straight pipe all the way out, so i'm looking at needing to install a catalytic converter and muffler.
any recommendations for what type of cat works best with our engines?
Most other tdi forums are full of folks talking about cat deletes and mufflrectomies.... i know the ecomodder crowd is into efficiency, so i hope someone is still monitoring this old thread and has some bright ideas about the best cat for an mk4 tai.
thanks!
Old 04-07-2017, 12:27 AM   #54 (permalink)
MaxHedrm's Avatar
Golf TDI - '10 Volkswagen Golf TDI
90 day: 37.69 mpg (US)
That actually will make it make more power andbe more efficient. So, unless you want it quieter, I wouldn't worry about the muffler. As for the cat, I'm not sure what that age would have had, mines the DPF Mk6.
Driven: 2010 VW Golf TDI
Driven less: 2001 Audi TT Roadster (225)
Parked: 1982 VW Jetta Diesel
Old 04-07-2017, 12:35 AM   #55 (permalink)
i personally don't care about the increased sound, but i couldn't pass state inspection without muffler so looking into what to do about that..
and i'd been ignorant and thought only gas engines had cats!
Old 04-07-2017, 07:11 AM   #56 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
throw a cherry bomb muffler on it. It will work until it packs up with soot. It may get you past inspection. Diesels don't use cats per say, They have a DPF (which the newer ones have catalytic properties ) and you will have to buy a new one because it is against the law for junkyards to sell them used.
Old 04-07-2017, 07:44 AM   #57 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I don't know, but I think you may find that just a catalytic converter may get the noise level to your liking. Probably easiest way to get one is a post on the private for sale area of TDI club.
I'm running a generic catalytic converter for a 1 ton diesel pickup on my car, along with the cat back for a 1.8T. I used to think it was really quiet, but now that I EV it seems kind of loud, but no worse than a Prius (with ICE running).
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 04-07-2017, 07:48 AM   #58 (permalink)
EV OR DIESEL
Originally Posted by ConnClark View Post
throw a cherry bomb muffler on it. It will work until it packs up with soot. It may get you past inspection. Diesels don't use cats per say, They have a DPF.
US spec Diesels typically do have a catalytic converter (his TDI did in the states), newer (07+) typically have a catalytic converter and a DPF, VW has taught us that a NOX trap with DEF is basically necessary as well.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
The Following User Says Thank You to dremd For This Useful Post:
COcyclist (04-07-2017)
Old 04-10-2017, 12:00 AM   #59 (permalink)
would it matter if my 2004 Golf is actually a Canadian?
Old 04-10-2017, 01:49 PM   #60 (permalink)
EV OR DIESEL
I don't know, if I had to guess I'd say the emissions system was the same.
2016 Tesla Model X
2022 Sprinter
2012 Nissan LEAF SV
