Register
Now
Reply
Old 06-30-2008, 09:09 AM   #21 (permalink)
The Truck - '02 Ram 1500 SLT Sport
90 day: 19.78 mpg (US)
The Van - '00 Odyssey EX
90 day: 19.53 mpg (US)
To make generalizations one of the things common among commercially-available cold air intakes is that they replace the stock air filter box and short hose to the throttle body with a long tube placing a reusable filter near the front of the vehicle and somehow duct the stagnant air from the nose to this filter.
The "wave theory" brought up by whatthe could more than explain how such a setup would improve fuel economy. By using a longer intake duct you are actually tuning the intake to improve volumetric efficiency at a lower engine speed. Engines do not pull air at steady flow but rather in pulses as each cylinder fills only once every two revolutions and no two cylinders fill in unison. CAIs often produce a sound because they eliminate a resonant chamber (the air box) and replace it with an organ pipe (the tube) thereby allowing that unsteady flow pulse to resonate and produce sound. Since sound is an alternation of positive and negative sound pressures you can acoustically tune your engine to shift the torque curve to a lower engine speed. When it is in tune the positive air pressure pulse will continue past the throttle and hit the open intake valve improving port velocity (increasing swirl and chamber turbulence, improving fuel burn and reducing knock tendency). The acoustic pressure pulse induced by the unsteady intake flow will likely exceed any "ram" pressure seen at normal highway speeds.
If the torque curve were improved VERY low in the engine speed range, below 2000 rpm, this could very conceivably improve fuel economy by allowing more high-load operation without lugging or allowing earlier upshifts. Shifting torque to a lower speed could shift a BSFC iso-efficiency island lower as well. I envision improving ultra-low speed torque (and efficiency) improving hypermiling by allowing a shorter-duration higher-load pulse followed by an EOC, effectively decreasing the percentage of the time the engine is on and under load.
As much as hypermiling depends on DIY and testing to compare I'm confused by the overt hostility to a mod just because it is perceived as a "performance" mod for racer-types. I tend to think most people's perceptions are wrong and would rather see data. If someone could do a good a-b-a on any mod and prove a FE improvement I'm all for it but debating the merits in the absence of data using only preconceived notions or dismissing an improvement because it's negligible (it's *still* an improvement) seems like a waste.
Old 06-30-2008, 11:00 AM   #22 (permalink)
Power tuner gone eco
whatthe's Avatar
Clio - '92 Swift GT
90 day: 45.03 mpg (US)
Great post. I couldn't have summed it up that well. Cylinder filling and length of intake duct were my thoughts exactly. A longer pipe should lower the rpm that this theoretical improved filling occurs at.
The question of do you want a 2, 3, 4, or 5 foot pipe on the end for your car should find it's own answers on a forum like this. I'll try different lengths just to see what works.
I couldn't agree more with you on this as well. It seems all too often that you come across a post on a car forum where the poster says 'that sucks' without a list of reasons or data to show why.
1992 - Suzuki Swift GT
Old 06-30-2008, 11:01 AM   #23 (permalink)
IMO, CAI will hurt you. A tuned intake system could help you (some?), but only at a a very limited rpm/load range. More applicable to stationary engines driving load controlled generators at fixed rpm.
Low rpm is not an all good thing either - piston speeds are lower so the conversion of heat into movement is less efficient.
Old 06-30-2008, 12:48 PM   #24 (permalink)
Acoustic effects significant to FE lie between the throttle valve and the intake valves. Nothing upstream of the throttle will change the acoustic tuning at these part loads.
Keep you air filter reasonably clean and you'll do fine, unless you want high RPM power. FE calls for limited amounts of air so efforts spent tweaking out a small pressure drop are most definitely spent elsewhere.
Old 06-30-2008, 01:24 PM   #25 (permalink)
It goes without saying a-b-a controlled experiments, especially with different lengths of pipe to test the applicability of Mech's wave theory, would be far and away more conclusive and useful than a forum theoretical discussion. Keep us posted, whatthe. Until then we don't have any.
Secondly, I'm going to do something dumb and defend myself against these oblique attacks on my character, but I don't understand why this has to be personal. "Overt hostility?" I think not. I do not care whether CAI's are performance mods, but that is what they are designed for. So when someone comes by and says "btw, they increase fuel economy too, here's my hunch as evidence" a little red flag goes up in my head. Now Mech has finally presented a theoretical explanation, good, lets test it!
Finally there is no such thing as a negligible improvement, it either offsets the cost of installation, labor, and additional noise or it doesn't.
I guess, whatthe, my list of reasons for saying "that sucks" is no explanation towards how its possible (until Mech's post), no data to the contrary, and no adoption from the factory (except in sports cars). Manufacturers take great pains to tune their intakes (albeit mostly for noise reduction), and if CAI's were worth it they'd be everywhere. Again, sorry this is personal, but it seems all too often that you come across a post on a car forum where the poster says 'this is magic' without a list of reasons or data to show why.
1987 Chevy G20 high-top van - 305, TBI, 11MPG on its only trip
Old 06-30-2008, 01:36 PM   #26 (permalink)
whatthe's Avatar
Clio - '92 Swift GT
Stock fuel cut on my GT is 7500rpms. Max FE for me is going to be below 4000rpms and if I'm hypermiling I should theoretically never see above 4000 again. Therefore, my factory intake is poorly tuned for the 750-4000rpm range and it is an area worth investigation. Although, I will say that I do agree that CAI is not necessarilly the way.
Why do you say that acoustic tuning will not be effected at part load? As I see it, the air is still pulsing even past the throttle valve. If you go home and stick an 8 foot section of pipe on your intake, go for a drive, and tell me that it didn't make a difference at part throttle.... I will be incredibly surprised. I have an exhaust/intake theory book that has a few graphs showing the effects of cylinder pressure/filling against valve opening for a few different lengths of intake. This length of pipe was placed before the "carburetor/intake manifold" (older book).
From an incredibly limited experience stand-point, and a premature update for Vanner, I put a 6-7 foot length on my GT yesterday, put the wideband on, and went for a drive today. The pipe is longer than the theoretical values I was thinking of, but I used some old intercooler pipes and common sense says it's easier to make it shorter than longer later. There have been some interesting changes that I can better get into after a tank of gas.
Old 06-30-2008, 01:43 PM   #27 (permalink)
Some people will never be convinced no matter how overwhelming the evidence. Oh well.
http://www.karlsnet.com/mopar/ramair.shtml
Old 06-30-2008, 01:50 PM   #28 (permalink)
Tuning upstream of the throttle valve will change the acoustic signature (sound levels) apparent to the driver and outside environment, yes. Car makers add Helmholtz resonators to the intake boxes to quiet certain frequencies that would sound objectionable to the driver.
But those effects are lost on the other side of the throttle valve, inside the manifold. Acoustics there, which would cause local pressure wave optimizations right at the intake valve (for improved volumetric efficiency) are almost entirely (>90%) caused by reflections between the throttle plate itself and the various parts inside the manifold and intake ports. The throttle valve is still more than 50% closed at those operating points where we run for best FE, so that plate is a HUGE chamber end reflector for acoustic waves inside and outside the manifold.
Now, open the throttle valve and yes, the entire intake system becomes important. A plate at 90 degrees to the flow will have a minor acoustic impact. Racers and those looking for wide open or no, (i.e. diesel) throttle operation should look at the impact of the whole system for tuning effects.
A bit off topic, but for part throttle FE I think we'd be better off looking at a tuned exhaust system. That's always "wide open" and adjusting its length for constructive interference acoustics at the exhaust valve (where constructive means improved breathing) will work at ALL throttle openings. With a better exhaust flow you ought to reduce the total engine friction, but overdoing it could cause some of the incoming intake charge to be pulled right out of the exhaust valve. Reducing cam overlap could help optimize that.
Old 06-30-2008, 04:48 PM   #29 (permalink)
I agree, either tune for resonance from the throttle downstream or work on the exhaust. Possibly something could be done with rubber diaphragms instead of long pipes (think drum vs organ pipe).
75% or so throttle is best for acceleration, but we don't do much of that and so are most often at less than 20% (ie, mostly closed).
Old 06-30-2008, 09:26 PM   #30 (permalink)
I can has ecomodz?
Formula413's Avatar
S. Court El Ecks - '97 Escort LX
90 day: 34.02 mpg (US)
The Beast - '97 Firebird Formula
Spock - '92 Vulcan
90 day: 56.15 mpg (US)
Originally Posted by johnpr View Post
I'm aware of what the factory rated them, the truth is you put an un-modded t/a next to a ws6 and race them and there is no definate which is the faster car. this has been debated time and again on ls1tech.com and each time it comes out the same - they are equal cars.
Correct. As another F body guy I can attest to this, I have seen dyno sheets. The widely varying ratings for different LS1 engined cars (Z28/Trans Am, SS/WS6, Corvette) are just marketing, not reality. All LS1 powered cars made very similar power.
Choices, choices...
Old 07-05-2008, 03:10 AM   #31 (permalink)
whatthe's Avatar
Clio - '92 Swift GT
Manufacturers have also used Helmholtz resonators for wave ram effect at low rpm (diesel apps).
Yes, the majority of benefits are going to come elsewhere, however the air still enters at the air filter at all rpms and throttle conditions... so, perhaps it's the wrong view to consider it a more crushed or disturbed "slinky", but air still has to come from point A and slinky it's way back to end up at point B (at least in my mind and not accounting for inertia effects, etc).
I swapped a 1.8L mazda BP into an MX3 years ago and I recall there being an H-box inline with the flapper MAF (most of the boxes seem to be placed after filter, off to side, or whatever). On that particular car, even if it 'shouldn't' have, torque output decreased removing the h-box. Mazda was big into their resonance tuning at that time, but perhaps its more likely that it changed something with the MAF or air going through MAF and that was the performance drop I felt at the time.
At any rate, for the Suzuki - the longer pipe definitely reduced some objectionable noise. Also my perception to torque, etc.. changed, but it would be nice to put it back on the dyno to have actual data. The car gained a few more mpg, but this could also have been attributed to changes with my right foot or the MAF.
The big drawback is that just like a CAI, it changed how the air goes through the MAF and thus altered the MAF signal and thus effects results. When I say these MAFs are sensitive, I really mean that they are sensitive. I can take this car from 18:1 lean at part throttle, to 11:1 rich at anything over 10-20% throttle just by changing pipe diameters, in front of and behind the MAF.
I datalogged a few of the runs with the wideband against tps and rpm for future reference. This also alerted me that this car is going too rich too early and of some other issues. Going to fix part of those issues for the next tank.
This is just more a comment that some of these tweaks really will be vehicle specific. Like I say, CAI likely will cause problems on a hot-wire MAF type vehicle just because of the design of the sensors. If the ECU doesn't compensate well enough, you could see very little or no performance increase, and less mpg.
If you have a Honda or some other commonly MAP sensor based vehicle... you may want to try cramming as much air down the throat as you can to see what results you can obtain.
Old 07-06-2008, 05:03 PM   #32 (permalink)
VIVA LA MPG RESISTANCE
Will's Avatar
Meat-ro - '97 Metro
90 day: 51.6 mpg (US)
Wife's Brruik - '03 Century
90 day: 29.53 mpg (US)
I took a rather stupid approach and used a 4" dryer vent from my air filter, up the side of the engine compartment and dropped it out into the grille. It looks dumb, but it seems to help. I noticed a 2.4 mpg gain, but that could have just been me, as I am new to this....
Old 07-06-2008, 10:23 PM   #33 (permalink)
whatthe's Avatar
Clio - '92 Swift GT
I don't think it's dumb at all... the air isn't pressurized and it gets it from point A to point B... grassroots is good!
Reply
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 17 08-14-2008 07:19 AM
Conversion idea, 2L inline 4 -> piston boosted 1.0L 2 banger? Warning....Long thread JoJotheTireMan EcoModding Central 44 07-01-2008 05:12 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 45 05-03-2008 04:33 PM
AutoSpeed article: spoofing the intake air temp for slightly improved MPG MetroMPG EcoModding Central 13 04-30-2008 10:13 AM
Honda IACV explained TomO Off-Topic Tech 0 02-09-2008 12:32 AM
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0 RC5
