Old 04-19-2017, 03:43 PM   #1 (permalink)
Kill switch and engine start button wiring
Hi all
I am planning on installing an engine kill / engine start button arrangement on my 2003 C220 CDI Manual.
The engine start button is easy, just wire it into the starter relay.
The engine kill button is a bit more difficult. I am planning on using a normally closed switch into one of the wires on the CAM position sensor.
If I unplug the cam sensor, the engine stops, but I have to cycle the key for the engine to start again.
any ideas which wire I can tap into to simulate a 0 RPM signal?
Old 04-19-2017, 04:30 PM   #2 (permalink)
Eco Sol
Shortie771's Avatar
Why not kill the engine at the injectors? That's what I did. I wired my switch to the under-hood injector fuse. So when I flip the switch, it's pretty much the same as if I had taken the fuse out.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 04-19-2017, 04:33 PM   #3 (permalink)
The common rail injectors have sizeable power feeds. I would have to use a relay and it also logs a EPC fault code which fills the screen on the dash.
Old 04-19-2017, 04:34 PM   #4 (permalink)
Eco Sol
Shortie771's Avatar
Well darn. I guess I had it easy since I'm OBD-1... Back when things were lower tech
CR-Z Current Mods:
Max Sidewall PSI
Old 04-19-2017, 04:35 PM   #5 (permalink)
It is noticeably more difficult than my other cars.
EOC on motorbikes is traditionally easy, just hit the kill switch. My bike has a DCT gearbox that wont go into gear until its stopped! Argh
Old 04-19-2017, 04:38 PM   #6 (permalink)
Eco Sol
Shortie771's Avatar
That seems like a lot more trouble. Sadly I think you're out of my realm of knowledge. I'm sure somebody (smarter than myself) here can offer you a solution.
CR-Z Current Mods:
Max Sidewall PSI
Old 04-21-2017, 02:44 AM   #7 (permalink)
SUVcruiser - '07 Ssangyong Kyron 2.0 XDI
90 day: 42.55 mpg (US)
SUVcruiser year 2017 - '07 Ssangyong Kyron 2.0XDI
Hybridcruiser 2023 - '13 Volvo V60 D6 AWD
90 day: 123.84 mpg (US)
I bump start my engine. But i need a kill switch. Cycling the key is not good for wear. And when dark. The lights go out until i switch the key back to on...
Drive smart, save fuel, save money, spare the enviroment
But keep having fun!
I can drift
Previous car. SUV. From 2011+ 10l/100km to 2017 5,516l/100km.
2017 without holiday: 5,397l/100km
EPA Rated average: 8,1l/100km
Current ride: plug in 285hp hybrid
EPA Rated average: 2,8l/100km
Old 04-21-2017, 07:38 AM   #8 (permalink)
After some testing, the only way to kill the engine is by cutting the CPS signal so that the ECU thinks the engine has stopped.
Any other method (removing the injector connector, rail pressure sensor etc) causes the ecu to need a key off/on again before it will allow the engine to start.
Will put a pic up soon of the switch arrangnment.
Old 04-21-2017, 08:27 AM   #9 (permalink)
Eco Sol
Shortie771's Avatar
I'm guessing a fuel pump cut or ignition kill switch wouldn't cut it?
CR-Z Current Mods:
Max Sidewall PSI
Old 04-21-2017, 08:28 AM   #10 (permalink)
As its a common rail diesel, there is no electrical fuel pump or ignition system.
