05-23-2018, 01:45 AM
L.A. is Plasti-Dipping their streets.
They claim they are making their roads white--it goes on white, but dries grey, and they say it leaves the surface 10° cooler. It costs $40,000 per mile and lasts seven years. One complaint? Yes, it reflects the rising and setting sun. https://www.mnn.com/earth-matters/cl...ainted-streets
05-23-2018, 02:28 AM
Or, you could simply pave in concrete, which is a legitimate option in sunny California.
05-23-2018, 03:10 AM
Sounds horrible to drive on due to the increased light, but hey, the road is 10 degrees cooler, so who cares that it costs a fortune and will cause more accidents.
I read somewhere that concrete roads are more cost effective in the long run than asphalt, but nobody wants to front the initial cost. It also reduces rolling resistance if I remember correctly.
05-23-2018, 03:13 AM
05-23-2018, 03:24 AM
Asphalt roads are 7dB quieter than concrete, so there is that. Turning the volume down | Asphalt magazine
Ten or fifteen years ago a radio host commented he was looking forward to driving on the newly-rubberized section of the 101, which made his car feel like a Mercedes.
I thought sunny CA would have roads made of solar cells by now.
05-23-2018, 03:28 AM
Oh Oh! If that reduces the effectiveness of all that "Rolling Thunder's" muffler deletes and sub-woofers, what will they do to get the attention they crave?
If the roads are rubberized and squishy, do we still need tires?
05-23-2018, 03:59 AM
Years ago, I asked my dad "Why don't they make roads out of rubber, and tires out of concrete?" thinking, we'd never have to replace tires. (Yeah, I was THAT young.) He just looked at me like I was the fool that I was.
What's the idea of rubberized roads. A place to get rid of worn out tires?
05-23-2018, 04:07 AM
#9 (permalink)
Twenty years ago I passed a crew resurfacing a road. A truck's tires were covered with asphalt.
How long do those tires last? Do they need to replace them when they have too much asphalt?
05-23-2018, 04:30 AM
#10 (permalink)
Big difference. There's a reason that NEDC "cheating" test facilities use trick asphalt... you get a mathematical bonus for using asphalt in the tests, because it is higher friction than concrete. Then you slick it down for lower friction and take advantage of the unfair multipliers.
