Old 11-22-2015, 02:40 PM   #51 (permalink)
100 mpg 1 tonne truck
teknomage2012's Avatar
Z - '77 Datsun 280Z 2+2 custom
90 day: 31.85 mpg (US)
Bumble Bee - '06 www.mpgtrikes.com nomaOmatic x1
90 day: 76.46 mpg (US)
VW Caddy Pickup Truck - '81 Volkswagen Rabbit Caddy Pickup Truck
90 day: 33.1 mpg (US)
KLR - '09 Kowasaki KLR 650 Dual Sport
90 day: 54.65 mpg (US)
The Juggernaught - '65 Gillig 35' motor coach
90 day: 6.55 mpg (US)
hummingbird - '81 Volkswagen rabbit vx
90 day: 165.09 mpg (US)
HD Ruby - '12 nissan leaf sl
90 day: 99.66 mpg (US)
Eco Ruby - '12 Nissan Leaf Sl
90 day: 169.6 mpg (US)
Billy - '01 Dodge 2500 2wd
90 day: 18.38 mpg (US)
Send a message via ICQ to teknomage2012 Send a message via Yahoo to teknomage2012
The battery heat problem was solved with the first chemistry change in 2013 from that used in 2011 and 2012 leafs; and now the chemistry change of 2016 batteries and forward have the heat issue solved the same as 2013 and newer but with an additional 30% increase in capacity... it may not (yet) be Moores law but it is rapid and reasonable for a budding industry.
And just wait till the aftermarket starts dissecting ev's for and with upgrades and performance mods
Old 11-22-2015, 03:25 PM   #52 (permalink)
Teknomage, there is no evidence that the '13 chemistry change significantly affected durability compared to '11-12. While '15+ maybe improved, it's still too early to know how much.
You can be reasonably sure that the '16 30kWh chemistry is improved given the significantly better warranty.
IMO the increase unusable range that the 30kWh pack will give over the 24kWh makes it a no brainer unless you are leasing for 2-3 years or don't ever need more than 50 miles of range between charges for as long as you plan on keeping the car.
Over on TMC there are guys looking to do aero covers but instead of drilling the wheels they are using extended lug nuts with M5 holes tapped into them for mounting the cover. Seems like a much better way to do it as you avoid permanently modifying the wheels.
Old 11-22-2015, 04:09 PM   #53 (permalink)
What's on it's way in the next few months from one supplier is a re-furb Telsa drivetrain, with the firmware flashed to support the reverse-engineered CAN bus controls; ready to drop into your '64 T-Bird or jet black Hudson Hornet 4-door.
Old 11-22-2015, 05:08 PM   #54 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
That's the consensus I've been seeing on the LEAF forum for a while now.
I'm probably going to pick up an 11-12 anyway and hope for the best.
I'd prefer a news one, but I wouldn't feel bad screwing around with the 11-12 at the prices that they go for.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
