05-05-2017, 03:51 PM
#21 (permalink)
Originally Posted by Vekke
Citroen C5 "steel" 6.5x15" 4x108 ET 18 Weigth 4.7 Kg = 10.36 lbs
Its actually 6x15", but yes, these are amazingly light and cheap to obtain.
'97 Ford Escort 2010-2010†
'90 Citroën AX GTI 1.4 mpi 2010-2012†
'96 Citroën AX Diesel 1.5D 2012-2016†
'95 Citroën AX w/ TU5J4 1.6 16V swap 2015-2016†
'92 Citroën AX w/ TU5J4 1.6 16V swap #2 2016-
'02 Renault Mégane wagon 1.6 16V on LPG 2016-
05-05-2017, 05:23 PM
#22 (permalink)
Eco Sol
Too bad you don't see Citroens in the US. I'd totally get some of those. Also they aren't flashy, so no reason not to put on moon discs.
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
05-06-2017, 03:08 PM
#23 (permalink)
Cyborg ECU
Originally Posted by MPGomatic
My HX wheels need to be refinished. Wondering how much weight powdercoating or clear coat adds …
All I did was google, but I found a site that claims coating a set of 15" wheels should require 2 lbs powder. More than I thought. That is 4 or 8 added pounds rotational mass.
04-14-2018, 01:45 PM
#24 (permalink)
Wonder, imagine, test
Searching for light wheels for my 99' Aurora.
Does anyone have links to find the lightest 7J 16" et40 wheels? Or any wheel size sufficiently compatible.
"Audi A8 D2 5x112 ET42 7 J x 16" are pretty light in the list, and maybe compatible... My car has 5x115 bolts.
But I can't find any for sale even if they are compatible.
04-14-2018, 09:08 PM
#25 (permalink)
They aren't 16" and I don't have numbers, but I was shocked by how light the wheels on my volt are. They are 7x17, 5x115, 38mm offset
04-14-2018, 09:52 PM
#26 (permalink)
I don't know how light weight they are, but the Canadian GE (2009-2013) Fit LX model had these wheels in the 15" size: http://i90.photobucket.com/albums/k2...sc00811lwh.jpg which look very similar to the 14" wheels on the 1st generation hoda insight. Unfortunately they weren't available in the US. Aluminum, with the benefit of the very flat face for aerodynamics... perhaps we can come up with another list for highly aerodynamic wheels...
04-14-2018, 10:54 PM
#27 (permalink)
Just cruisin’ along
Originally Posted by Shortie771
Under 12lbs for my stock '97 wheels? I'll have to weigh my wheel covers, but if that's true, I just got a lot less interested in other options...
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
04-14-2018, 11:50 PM
#28 (permalink)
The two that always stand out to me are you afore mentioned Civic VX wheels and the RX7 FD wheels.
04-06-2021, 12:53 PM
#29 (permalink)
In case someone search for these wheels, here are original part numbers:
AFAIK, the difference is lug nut shape (flat and sphere) and L7 should be the lightest.
They are still on sale and pretty cheap.
