Old 06-11-2008, 07:14 PM   #11 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
i know that the two continental tires listed perform really well in incliment weather, the extreme contact is a great summer tire but it will work in the snow (just not that great), but then again, a vehicle which you would put that tire on shouldnt be in the snow to begin with.
i cant speak for the other tires though, i used to sell continentals and have a bit of brand loyalty because of the quality.
Old 06-11-2008, 09:03 PM   #12 (permalink)
Impatient Driver
chrislk1986's Avatar
98CivicHX - '98 Honda Civic HX
90 day: 40.02 mpg (US)
I got a mint pair (two) of tires mounted on 16" wheels. I always filled them to 40psi because I thought it was the max pressure, but I looked at them a couple weeks ago and they are 50 psi, the 40 was for mounting.
Will they say LRR on the tire if they are LRR tires?
Old 06-11-2008, 10:23 PM   #13 (permalink)
what set of tires?
i dont think i have ever seen a set of tires which advertised (on the tire) low rolling resistance, although you never know.
Old 06-11-2008, 10:47 PM   #14 (permalink)
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
I believe the Michelin energy Mx4's are being phased out as well.
I just got my second pair, and they were on closeout at tire rack.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
Old 06-11-2008, 11:52 PM   #15 (permalink)
Red
Red's Avatar
Would be a good marketing trick, selling tires as FE friendly.
Old 06-13-2008, 06:59 PM   #16 (permalink)
ecoModding beginner
07b2300's Avatar
07b2300 - '07 Mazda B2300
90 day: 27.97 mpg (US)
Thanks for posting this rolling resistance result from CR Daox.
Does CR have any ratings for low rolling resistance light truck and SUV tires too? All I can find on the web about rolling resistance are for old brands like the Michelin LTX M/S and the Goodrich Long Trail T/As. Both are supposed to have decently low RR but there are many newer brands that look like they would have less drag. Of course nobody lists RR figures...
Old 06-18-2008, 07:02 PM   #17 (permalink)
Here are the light duty tires CR has listed as achieving their best rolling resistance rating. Again, higher overall rated tires are closer to the top of the list.
All-season
Bridgestone Dueler H/T D684
Michelin Cross Terrain
Continental ContiTrac SUV
BFGoodrich Radial Long Trail T/A
All-terrain
Continental ContiTrac TR
Old 06-18-2008, 07:38 PM   #18 (permalink)
I had those Long Trail T/As on my former Escape, and they were great in the rain and snow. I'm planning to put a set of them on my Sedona in a few months time.
Old 06-19-2008, 08:13 AM   #19 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 32.04 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
Originally Posted by zjrog View Post
I must ask, how do these tires fair in inclement weather (snow)? And will they hold a wet road in corners? I'm going to guess that to aceive low rolling resistaqnce they are a harder compound and require a little higher pressure?
Really, I don't know how else to get lower rolling resistance... Is there a good website to see all these characteristics?
Sidewall stiffness, internal friction. Anything that prevents the tire from deforming as it contacts the ground will reduce rolling resistance. Harder compound materials do this by reducing how completely the rubber fills the "roughness" of the ground surface. A stiffer carcass (the guts underneath the rubber and tread) will deform less for a given load/pressure and generate less internal friction. Higher air pressure is just one method for reducing carcass deformation. Material choice will help, such as not using carbon black to color the tire but other materials that produce less internal friction as the tire does deform (I think Michelin pioneered the use of silicon in the MXV4 tires to do this)
Even tread design can help reduce rolling resistance since a tall/skinny tread block will squirm as it hits the ground and generate friction. Making the tread blocks themselves stiff and stable helps, and any design that reduces noise generation is more efficient since noise is just one other way energy is dissipated by tires.
Old 09-13-2008, 08:57 AM   #20 (permalink)
is there a more updated list?
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-25-2016 11:39 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 08:43 PM
Increasing gear ratios extragoode EcoModding Central 29 05-23-2011 03:36 PM
