03-31-2017, 12:42 AM
EcoModding flying lizard
Low RPM load limits? Lugging?
What load limits do you use when you are at low rpms? I find that below 1500 rpm, operating at too high a load makes the engine sound and feel rough, which I assume is nearing the lugging point.
idle-1300: 40% load(sometimes a little more)
1300-1400: 50% load
1500-infinity and beyond: No limits
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
Originally Posted by MetroMPG
You can lead a fashion-conscious horse to unusual-looking water...
03-31-2017, 01:03 AM
Cyborg ECU
Below 1500 is probably always too low for flooring it for any purpose at all. But above that, in a naturally aspirated and relatively low-power engine that is also in good working order, there is not much chance of damage. ECUs will adjust timing and AFR as needed to avoid pre-detonation. Nonetheless, 1500 is my absolute bottom for relatively high load (75%, which is a long way from WOT). But generally I am at 1700 or higher as I accelerate. Been doing this for years all the time and have 248,000 miles on the original engine now.
Great video here:
03-31-2017, 02:08 PM
In my Insight, the engine feels fine wide open down to maybe 1200rpm. At those low revs, even barely touching the pedal is enough to give it 100% load, because it needs so little air.
Edit: Recently passed 220k and it still runs like a brand new engine.
03-31-2017, 07:56 PM
Drive by wire throttle won't let you do anything that's bad for the engine, IMO.
03-31-2017, 08:04 PM
For my 8L engine build I would like to cruse along at 70mph turning 1,400rpm. If the engine doesn't like that I will have to change rear end gears.
04-01-2017, 12:20 AM
Not nearing . It is the indicator of lugging. Roughness is lugging beyond what the computer is able to maintain smooth operation.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
04-01-2017, 01:25 AM
Number of cylinders and/or displacement count, imo.
My 3 cylinder Geo isn't much good under 2000rpm at heavy load, whereas my wife's V6 happily chuggs down the the highway at 1500rpm. My Miata (read: DOHC/high-revving) is a turd below about 2500 rpm.
04-01-2017, 11:13 AM
Eco Sol
That guy does such great tutorials. My head feels funny, did I just learned something?!!
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
04-01-2017, 02:01 PM
#9 (permalink)
Have I missed something here? All the BSFC graphs I see seem to show that the engine is less efficient at low RPM & higher load.
04-01-2017, 02:24 PM
#10 (permalink)
Here's mine:
