View Poll Results: What will the results of A-B-A testing show?
Reduced drag vs. normal grille block
58 |
48.33% |
Increased drag vs. normal grille block
23 |
19.17% |
No significant change
16 |
13.33% |
AAAAAHHH! MY EYES!!
43 |
35.83% |
08-19-2009, 07:05 PM
#11 (permalink)
Oh yes, the Crisis Fighter Pinto! I forgot about their massive air dam. (So much info passes in one eye and out the other...)
From the Car and Driver report:
For maximum effectiveness, this one was designed with only two inches of ground clearance and as much of a wedge contour as possible to split the air in front of the car
At seventy mph, that simple sheet of aluminum added 0.9 miles per gallon to our test Pinto. [From 14.5 mpg unmodified, at 70 mph]
EcoModder blog: Crisis Fighter Pinto
08-19-2009, 07:11 PM
#12 (permalink)
Pokémoderator
MetroMPG -
The Pinto is what I was thinking about also :
( 14.5 + 0.9 ) / 14.5 = 1.062 => 6.2% Improvement @ 70 MPH.
CarloSW2
08-19-2009, 07:35 PM
#13 (permalink)
T-100 Road Warrior
What kind of support do you have on the bottom edge? I dropped my air dam really low with coroplast and the bottom edge had a tendency to fold in/over at higher speeds...especially when the air got dense with humidity.
08-19-2009, 07:58 PM
#14 (permalink)
There's nothing running the full width of the bottom edge, but there are 4 folded V-shaped vertial wedges/braces supporting the face of the dam against the OEM bumper. Sort of like this:
The curved sides of the dam are reinforced at the bottom edge by a wide lip on the inside that goes from the outermost of the 4 braces, around to the edge of the wheel arch.
I've taken it up to 100 km/h so far, with no visible deformation ... only checked afterwards, though. I didn't rig my web cam for a live view.
08-19-2009, 08:01 PM
#15 (permalink)
I just realized the braces would be damaged if they hit something low down. I mean.. if they weren't cardboard... assuming a "good" version of this were made.
Better to have slightly shorter braces, and some sacrificial Home Depot lawn edging as the lowest point of the dam that could take a hit.
08-19-2009, 08:25 PM
#16 (permalink)
Grasshopper
so are the results in?
or are we still polling
08-19-2009, 10:27 PM
#17 (permalink)
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I think you're going to get called a ricer. I can feel it. Someone is going to mistake that as a lame attempt at reproducing a body kit....
#18 (permalink)
Ricer. :P
08-19-2009, 10:59 PM
#19 (permalink)
I still can't get over a 4-banger Pinto only getting 14.5mpg. My 4x4 V8 F150 does better than that unless I'm towing. Used to have an F250 4x4 with a 460 V8 that got 13-14 NO MATTER WHAT. There is something wrong with this equation.
I don't remember them being THAT bad, 70 mph notwithstanding.
I got around 20ish with my 283 V8 a/t equipped Nova- supposed to be 55mph but often was closer to 70.
Was their car messed up?
08-19-2009, 11:05 PM
#20 (permalink)
Grasshopper
im sure if i pull up to a light and rev
someone would call me a ricer
*shrugs*
