Old 10-26-2014, 02:53 PM   #71 (permalink)
Doh, some issues to work out. But, you got it spinning!
How bad is that rubbing?
Old 10-26-2014, 08:40 PM   #72 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
The inner CV boot makes contact with the motor shroud once per revolution. So most of the boot clears.
I may be able to change the shroud - remove the gauge metal thickness by drilling it out and just leave the rubber gasket.
If that does not work, perhaps I can remove some metal from the motor at the contact point. If the contact point is part of one of the vents, then I may be able to adjust the shroud (bend it) with a ball pien hammer (sp?)
I need to investigate the new axles to ensure that the extra space is required there as well. No use fixing a problem that will go away when the part in question is replaced!
Old 10-26-2014, 10:10 PM   #73 (permalink)
Dreamer
If you disconnect the speedo cable from the gearbox can you see if the sleeve with the slot in it (gearbox side) turns when the wheels are turning?
Another thought, I have never tried this, but could you use a cordless drill on low speed to turn the inner part of the speedo cable (cable side) to see if that gets the needle moving?
At least that way you could isolate it to a gearbox problem or speedo/cable problem.
The Following User Says Thank You to Astro For This Useful Post:
thingstodo (10-27-2014)
Old 10-27-2014, 12:41 AM   #74 (permalink)
I should be able to do that tomorrow
There is a pin on the speedometer that fits into a slot in the gearbox. I think that would be damaged by using a cordless drill.
Perhaps just taking it apart will show a problem. I read several warnings about taking it apart carefully to avoid damage .. perhaps I was not careful enough?
Old 10-27-2014, 11:02 AM   #75 (permalink)
Mazda MX6 Day 099 video 026 October 6, 2014
Remove back seat
Make a cardboard battery stand-in
Experiment with how the batteries can fit in the back seat/trunk
Mazda MX6 Day 099 Video 026 Oct 6 2014 1 - YouTube
Mazda MX6 Day 099 Video 026 Oct 6 2014 2 - YouTube
Take my wife's advice
Old 10-27-2014, 10:01 PM   #76 (permalink)
Speedometer cable
I got home late and have also underestimated the effort required to remove the controller.
Here's hoping I can get it looked at tomorrow!
Old 10-28-2014, 09:36 PM   #77 (permalink)
Mazda MX6 Day 100 video 027 October 9, 2014
Plans for the frame of the battery pack
Supported by the beam between the rear wheels
Discuss using wood and 2x4s instead of aluminum tubes - easier to work with and faster to prototype.
Mazda MX6 Day 100 Video 027 Oct 9 2014 - YouTube
Last edited by thingstodo; 10-29-2014 at 08:08 AM.. Reason: Corrected day number in title
Old 10-29-2014, 08:06 AM   #78 (permalink)
Mazda MX6 Day 101 video 028 October 10, 2014
Old 10-30-2014, 08:21 PM   #79 (permalink)
Mazda MX6 Day 104 Video 029 Oct 11 2014
More provisions for battery holder
Drill pilot holes, use jigsaw to cut out holes for 2 x 4s
Jigsaw clamp for the metal blade no longer holds well. The blade is loose and comes out, or jams and breaks
Mazda MX6 Day 104 Video 029 Oct 11 2014 - YouTube
Old 10-31-2014, 11:46 PM   #80 (permalink)
Mazda MX6 Day 106 Video 030 Oct 13 2014
Install 2 x 4 floor supports
Supports on rear beam
OSB subfloor
OSB floor
Mazda MX6 Day 106 Video 030 Oct 13 2014 - YouTube
