Old 09-15-2017, 04:59 PM   #1 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Mazda Sky Active X! (HCCI gas engine: compression & spark ignition)
Anybody else excited to see the new Mazda sky active x implementation? Mazda predicts a 30%+ fuel economy gain over current sky active G engines and it makes more horsepower similar to a 2.5 vs a 2.0. What is really curious is that under light load condition it runs on lean compression ignition, but under high load it swaps to spark ignition. I hear similarities to a new and improved vtec-e. Thoughts?
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 09-15-2017, 09:55 PM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
Always beware of the term 'up to'.
It's a 30% gain only in the narrow band that HCCI will operate in. So owners won't be seeing 30% reductions at the pump. It's a bit like lean burn or cylinder deactivation.
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
MetroMPG (10-25-2017), Xist (09-17-2017)
Old 09-16-2017, 11:37 AM   #3 (permalink)
I thought it would resort to spark ignition only to keep it smooth while idling or at an extremely low RPM.
Old 09-16-2017, 12:50 PM   #4 (permalink)
Dark Egg - '12 VW Touraeg
But if the 30% is specific to say 65mph that's perfect for highway cruising. The EPA test cycle doesn't pick up these kind of things which means manufacturers are discouraged from trying things that may actually be really effective in the real world. I have no idea if this is the case with this car but I always like to dig into the EPA raw data and look at the old standard highway cycle results. That number better shows what is possible to get if you try.
Old 09-16-2017, 11:27 PM   #5 (permalink)
This was the same problem with Mazda's iStop. The EPA city cycle doesn't show its effects, even though real world testing has shown a 0.5 to 1 km/l difference in 8 km/l traffic.
We have to wait to see what Mazda does. I am assuming that it uses HCCI over a wider cycle than GM's older system precisely because it uses spark-controlled compression ignition.
The Following User Says Thank You to niky For This Useful Post:
Xist (09-17-2017)
Old 09-17-2017, 07:48 PM   #6 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
I'm still excited about the i-stop. Restarting the engine WITH the engine is just too cool! I hope they pair it up in the mazda 3 with a manual! The new Mazda 3 is my go-to brand new car choice right now.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
Old 09-18-2017, 02:01 AM   #7 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Just read up on the i-Stop and it sounds amazing. How they get it to do what it does, reliably and without stressing the engine, is a feat of engineering.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 09-18-2017, 08:45 AM   #8 (permalink)
Team Turbocharged!
Pickups
Idle stop is pretty much ubiquitous nowadays. Renault's is said to be good for 400,000 cycles. That's once a mile for... well you know.
Mazda's is the best system, but in practice, I've tried to beat Renault's system and can't. My Fiat's is much more of a 'first gen' system, no where near as polished, but gets the job done usually.
Old 09-20-2017, 11:30 AM   #9 (permalink)
Nowadays with idle-stop, regen braking and some mild degrees of electric power assist are becoming more widespread, it would not suprise me to see starter motors becoming more overbuilt to stand those operating conditions, eventually integrated with the alternator/stator/whatever type of generator for a more compact packaging.
Old 09-29-2017, 02:20 AM   #10 (permalink)
To be fair, you still use a starter motor, but having the engine "parked" with one cylinder primed to fire lessens the strain on the starter and minimizes the amount of juice needed.
And, as oldtamiyaphile says: It's the best system. Much smoother than the auto-stop systems the Germans use.
Similar in concept to SkyActiv X. Integrating separately clever but (relatively) simple solutions into a system that is greater than the sum of its parts.
