Old 11-29-2012, 07:28 AM   #11 (permalink)
Originally Posted by arcosine View Post
19 mpg, Subarus suck at mileage, always lower than sticker. It's that stupid way too over square boxer engine.
Wouldn't be so quick to blame the oversquareness. When they released the FB20 they said they had reduced friction 29% from the EJ20. 29 whopping percent. That is huge. Of course, having a more modern combustion chamber design helps, but we all know how much friction has to do with fuel economy. 29% is probably on the order of removing all pumping losses.
Old 11-29-2012, 11:33 AM   #12 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
Not quick to blame, I had one a long time ago. You can reduce the friction all you want, but if the heat escapes through all that combustion chamber surface area, you loose.
- Tony
Old 11-29-2012, 11:59 AM   #13 (permalink)
ever_green's Avatar
gueff - '19 Mercedes Benz A250 4MATIC AMG
90 day: 30.55 mpg (US)
tire pressure is good, my exhaust smell is actually worst off now. my whole driveway smells like a gas station when i start it up lol. i thought oversquare allows for lower friction losses?! one reason why maybe my BSFC sweetspot is wide from 1500-4000rpm at %80+ load? i think this has more due to do with the all-wheel drive and slightly large fuel pump and 500c injectors. also from what i have read the AVLS system is almost 90% of the time in high lift mode. and as for heat as i said i never see it go below 88'c wether at idle or highway cruising. i'm sure this engine just doesn't like gas asdditives, i mean i had no problems getting 33mpg in summer highway, now when i cruise it just doesn't go above 27mpg. reminds of running e85 vs pure gasoline in fuelflex cars. i think maybe my expectations are too high...
Old 11-29-2012, 12:13 PM   #14 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I have had this with a bad signal for intake air temp. Car going way to rich during start.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 11-29-2012, 12:14 PM   #15 (permalink)
ever_green's Avatar
bad as in replace or clean? is that part of the MAF sensor? scangauge shows intake temp to be couple degrees higher than outside temp.
Old 11-29-2012, 12:45 PM   #16 (permalink)
Smeghead
Wire had a brake in it. The computer showed -40 (according to Ultra gauge) MAF is separate but the temp probe samples the same air and the computer corrects the MAF for intake air temp(this was on a the Ford though most MAF systems are similar). If your scan gauge is showing a close number I would not suspect a problem there.
The smell of fuel is pretty indicative of a very rich mix.
The Following User Says Thank You to bestclimb For This Useful Post:
ever_green (11-29-2012)
Old 11-29-2012, 03:18 PM   #17 (permalink)
Yea well, either way doesn't hurt to have double digit percentage increases in mechanical efficiency AND combustion efficiency (Mazda is undergoing a similar fuel efficiency leap lol)
But don't hate on short stroke engines, the BMW S65B40 for example is a beauty. Piston and head design matters more than dimensions anyways. Mazda Skyactiv engines may have good bore/stroke ratio, but the extremely high compression ratio usually gives the combustion chamber a bad shape, so they gave it that rather deep piston bowl. In fact the low compression ratio on the EJ engines probably helped the heat rejection (at a greater efficiency penalty of course).
Old 11-29-2012, 03:33 PM   #18 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Sometimes when fuel economy takes a dump in the winter it makes me want to drive much faster than normal just because I know its going to suck anyways...so if I pass you going 120km/hr compared to my usual 90 km/hr...that is why.
I keep all other items in place though..grill block, tires at 40 psi and block heater when below-15C...the entire year round..
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
Old 11-29-2012, 04:30 PM   #19 (permalink)
Master Ecomadman
arcosine's Avatar
Team Saturn
I don't like over square engines. Fine for performance, but not fuel economy. combustion surface area increases buy the bore squared. 100 mm bore has 50% more area than a 80 mm bore.
• Prius:
1,497 cc 1.5 liters in-line 4 front engine with 75.0 mm bore, 84.7 mm stroke, 13.0 compression ratio.
Honda CRX HF: Engine Bore/Stroke 75.0x84.5mm
Saturn S series: 82 Bore× 90 mm stroke
Honda Insight: 72 bore × 81.5 mm stroke
Subaru EJ25
Displacement: 2457 cc
Bore: 99.5 mm
Stroke: 79.0 mm
- Tony
Old 11-29-2012, 05:23 PM   #20 (permalink)
• Prius:
Subaru EJ25
Bore: 99.5 mm
Stroke: 79.0 mm
And the most efficient mega diesels in giant ships have a 3 foot bore and a 9 foot stroke, with a scotch yoke to eliminate piston side loads. Longer stroke means a better lever. Not many short stroke engines are in the top percentages for best BSFC.
regards
Mech
