Go Back   EcoModder Forum > Classifieds > For Sale
Old 08-29-2016, 12:36 AM   #1 (permalink)
The Blue Bomber - '95 Geo Metro
90 day: 52.09 mpg (US)
Nearly Complete Part Out of 1995 Geo Metro; Sensor Trickers
I owned this car for 6 years, then sold it to a local guy last year. He loved it and drove it for 15k more miles, but recently the rear driver side strut tower broke free from the body due to a terribly rusted wheel well. He relisted it for sale so I bought it back from him so I could part it out in its entirety instead of seeing it go to the junk yard & crushed in a few weeks.
Engine still runs well despite lower compression. As of 6/30/16, the compression numbers are 160/90/170. Over the last 1300 miles, the previous owner averaged 42.2 MPG.
I still have some rare, hard to find parts. All prices are best offer + shipping. PM for PayPal address. I will need your shipping address to give you an estimate as well. I will try to keep the parts list updated as much as possible and first post, first serve. If you don't see a part listed, please feel free to ask.
Also please keep in mind this will be parked in my front driveway, so I need to keep the wheels intact so it still looks driveable and so it can be easily towed away in the end. If you are local and want wheel related stuff, I'll need your old parts in exchange.
ACCESSORIES PARTS
Coroplast Grill Block - $5 + Shipping
Coroplast Rear Wheel Skirts - $10 + Shipping
Coroplast Partial Kammback - $10 + Shipping
MPGuino - $45 SOLD
OEM Jack - $6 + Shipping SOLD
OEM Lug Wrench - $3 + Shipping SOLD
1998 Chevrolet Metro Owner's Manual - $5
AXLES & DRIVE SHAFTS
CV Axle Shaft (Passenger) - $32 + Shipping
BRAKES
Brake Booster - $18 + Shipping SOLD
Brake Caliper (Passenger Side New) - $13 + Shipping SOLD
Brake Caliper Bracket - $8 + Shipping SOLD - Driver's Side
Brake Master Cylinder - $11 + Shipping SOLD
Brake Pad/Shoe (Brand New Pads) - $2 + Shipping SOLD - Driver's Side
Brake Reservoir - $6 + Shipping SOLD
Brake Rotor (Brand New) - $11 + Shipping SOLD 1
DASH/COWL
Air Bag, Single Bag - $40 + Shipping SOLD
Dash Trim Bezel - $6 + Shipping
Sunpro 2” Electrical Water Temperature Gauge with Pillar Pod Bezel - $30
Glove Box Complete - $9 + Shipping
Glove Box Latch - $4 + Shipping
Ignition Switch w/Key - $27 + Shipping SOLD
Instrument Cluster with Tachometer - $70 SOLD
Windshield Wiper Arm - $7 + Shipping
Windshield Wiper Blade - $2/ea + Shipping
DOORS
Complete Trunk Release Actuator - $40 SOLD
Door Complete Front - $75 (Local Pickup Only)
Door Handle - Inside - $4 + Shipping
Door Handle - Outside - $9 + Shipping
Door Hinge - $5 + Shipping
Door Latch - $11 + Shipping Passenger SOLD
Door Lock Cylinder - $2/ea + Shipping
Door Rubber - $2 + Shipping
Door Trim Pads (w/o Accessories) - $12 + Shipping
Door Black Pillar Trim Piece - $22 Shipped SOLD
Driver’s Side Remote Mirror - $15 + Shipping SOLD
Passenger Side Mirror Delete - $30 SOLD
Window Crank - $2 + Shipping SOLD
Window Regulator - $18 + Shipping
ELECTRICAL
Alternator - $33 + Shipping SOLD
Battery January, 2013 - $30 (Local Pickup Only)
Computer/Controller/Ecm - $24 + Shipping SOLD
ENGINE BOLT-ONS
Alternator Belt Tensioner (w/bracket) - $18 + Shipping SOLD
MPG Sensitive Cruise Control Kit - $175 $125 SOLD
Dipstick - $2 + Shipping
Dipstick Tube - $2 + Shipping
Dipstick W/ Tub - $3 + Shipping
Harmonic Balancer/Crank Pulley - $20 + Shipping SOLD
Oil Pump - $7 + Shipping
Pulley - $4 + Shipping
Starter - $33 + Shipping SOLD
Starter Solenoid - $5 + Shipping SOLD
ENGINE
3 Cylinder 1.0 Complete Engine w/XFi Camshaft (160/90/170) 298k miles - $220 OBO (Local Pickup Only)
XFi Camshaft - $125 $100 SOLD
Crank Shaft - $90 SOLD
Cylinder Head, (w/o Cam) - $39 + Shipping
Engine Block - $100 + Shipping
Oil Pan - $23 + Shipping
Piston & Rod Assembly - $12/ea + Shipping
Push Rod - $2/ea + Shipping
Timing Gear/Camshaft 60A +2* Sprocket - $25 SOLD
'92+ 1.0 Style Valve Cover - $58.99 SOLD
’89-’91 1.0 Style Valve Cover - $10 + Shipping
EXHAUST SYSTEM
Catalytic Convertor - $60 + Shipping SOLD
Exhaust Manifold Springs/Bolts - $18
FRONT END PARTS
Fender - $47 + Shipping
Headlamp Mount Bracket/bucket - $6 + Shipping SOLD
Hood - $58 (Local Pickup Only)
Hood Hinge - $6 + Shipping
Hood Latch - $7 + Shipping
Hood Prop - $4 + Shipping SOLD
FRONT SUSPENSION
Sway Bar/Stabilizer Bar - $17 + Shipping Front - SOLD
Sway Bar Link - $3 + Shipping
Turbine Tech Front Lower Underbody Brace - $190$163.55 SOLD
FUEL SYSTEM
Fuel Injector - $11 + Shipping
GLASS
Glass Door - $22 + Shipping
Glass Hatch - $40 (Local Pickup Only)
Glass-Quarter - $17 (Local Pickup Only)
HEAT - A/C
A/C Clutch - $15 SOLD
A/C Compressor - $44 + Shipping SOLD
A/C Condenser - $28 + Shipping SOLD
A/C Dryer - $8 + Shipping SOLD
A/C Evaporator Core - $18 + Shipping SOLD
A/C Hose - $12 + Shipping SOLD
A/C Button - $11 + Shipping SOLD
Blower Switch - $17 + Shipping SOLD
Blower Motor - $18 + Shipping SOLD
A/c Evaporator Core Housing - $24 SOLD
Heater Fan Resistor - $7 + Shipping
HVAC Knobs - $1/each + Shipping SOLD
Hvac Housing Complete - $40 + Shipping
Temperature Control - $30 $17 + Shipping SOLD
IGNITION
Coil - $12 + Shipping
Distributor - $30 + Shipping SOLD
Spark Plug Wire - $1 each + Shipping SOLD
INTAKE
Air Intake Complete - $20 + Shipping
Air Intake Lid - $4 + Shipping
Air Filter K&N - $25 + Shipping SOLD
Air Intake Hose - $6 + Shipping
E.g.r. Valve - $7 + Shipping SOLD
EGR Vacuum Solenoid - $7 + Shipping SOLD
Intake Manifold - $45 + Shipping
Throttle Body W/O Injector - $29 + Shipping
Throttle Body W/Injector - $40 + Shipping
INTERIOR
Dodge Neon Armrest (has two small holes for toggle switches) - $15 + Shipping SOLD
Clockspring - $24 $12 + Shipping SOLD
Center Console - $15 + Shipping SOLD
Glove Box Door - $16 + Shipping
Brake/Clutch Pedal Assembly - $60 SOLD
Shifter Assembly - $28 SOLD
Shifter Knob - $12 $2 SOLD
Sun Visor with Mirror - $16 $10 SOLD
LIGHTS/LAMPS
Foglamp Pair - $6 + Shipping
Headlamp, Sealed-Beam Sylvania Xtravision (One Brand New) - $2ea + Shipping
High Mount Stop Lamp - $8 + Shipping
Parking Lamp - $20 11x2 + Shipping SOLD
Tail Lamp - $34 $17 + Shipping Left Side SOLD
RADIATOR /ENG. COOLING
Radiator Dual Core - Copper - $35 + Shipping SOLD
Radiator Fan Assembly - $18 + Shipping
Radiator Fan Motor Only - $12 + Shipping
Radiator Fan Shroud - $15 + Shipping
Radiator Hose - $4 + Shipping SOLD
Thermostat Housing w/extra bung for aftermarket coolant temp. sensor - $30 + Shipping
Water Pump - $7+ Shipping
RADIO / AMPS
Sony Xplod CDX-GT120 Radio Am/Fm/CD/AUX + wiring harness - $45 SOLD
Speaker Grill - $5 SOLD
Pioneer Speakers - $5 each + Shipping SOLD
REAR BODY PARTS
Hatch Shock Pair - $6 + Shipping SOLD
Hatch W/glass - $70 (Local Pickup Only)
Hatch W/o Accessories - $45 (Local Pickup Only)
Trunk Latch - $18 SOLD
RELAYS/SWITCHES
Dual Stalk Multifunction w/9 Position Intermi SOLD Wiper Switch - $40 SOLD
Headlamp Switch - $19 SOLD
SEATS
Seat Belt (retractor) - $12 + Shipping Front SOLD
Seat Belt Buckle - $6 + Shipping Front SOLD
SENSORS
CTS & IAT Sensor Trickers - $50
Idle Air Control Valve/motor - $9 + Shipping $13 SOLD
M.a.p. Sensor - $8 + Shipping
Misc. Sensor - $7 + Shipping
Oxygen Sensor - $5 + Shipping
Throttle Position Sensor - $7 + Shipping SOLD
TRANSMISSION & CLUTCH
3.79 XFi Transmission ~140k miles - $225 Shipped SOLD
Flywheel 1.0 - $22 + Shipping
Inspection Plate - $6 + Shipping SOLD
WHEELS/TIRES
Compact Spare Tire - $12 + Shipping SOLD
Old 08-29-2016, 09:57 AM   #2 (permalink)
Lots of nice parts there.
The Following User Says Thank You to Daox For This Useful Post:
mjspiess (08-29-2016)
Old 08-31-2016, 08:58 PM   #3 (permalink)
Front Seat Belt Retractors & Buckles sold.
Passenger door latch and window crank have sold.
Old 09-05-2016, 11:32 PM   #4 (permalink)
Dodge Neon Armrest has sold.
Old 09-10-2016, 05:20 PM   #5 (permalink)
Starter and brake reservoir sold.
Old 09-11-2016, 10:20 PM   #6 (permalink)
3.79 XFi Transmission sold.
Old 09-15-2016, 12:44 AM   #7 (permalink)
Brake booster, radiator rubber/mounts & TPS sold.
Old 09-17-2016, 01:25 PM   #8 (permalink)
Driver's side brake caliper + brand new pads are sold.
Old 09-21-2016, 10:46 AM   #9 (permalink)
Hood prop plastic inserts sold...still have the actual prop.
Old 09-24-2016, 10:29 PM   #10 (permalink)
XFi camshaft sold.
