04-29-2016, 10:58 AM
#21 (permalink)
I plan to never find out!
2 air bags.
05-04-2016, 09:48 PM
#22 (permalink)
60 MPG short fill
So the Echo's temporary permit expired yesterday.
When I brought it home I filled it to the brim -- fuel visible in the filler neck. I filled it to the brim again yesterday -- same pump, same level, facing same direction, same ambient temperature.
Calculations say 3.9 L/100 km = 60 mpg US after 151 km. That's with about 50% sub/urban driving & 50% rural highway driving (max. 50 mph limit). No engine off coasting (because the ScanGauge version I had in it doesn't do 9999 mpg with the engine off and I was trying to calibrate it).
While that looks good, I'm a little skeptical. The ScanGauge said 50 mpg US.
We'll have to wait to find out which number is closer to reality. The car's now parked until late fall.
05-04-2016, 10:03 PM
#23 (permalink)
Just cruisin’ along
I'd be a little skeptical too. Not that it's impossible to get 60mpg, but...yeah, it doesn't feel right to me either.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
05-04-2016, 10:24 PM
#24 (permalink)
If I had been doing E-off-C instead of E-on-C, it would be easier to buy the 60 mpg figure.
Anyway, it's a mystery to be solved later.
Time now to finish testing the Prius mods, tidy it up & sell it.
11-09-2016, 08:30 PM
#25 (permalink)
Update: rust repairs
I started fixing the rocker panels. See:
http://ecomodder.com/forum/showthrea...ics-34525.html
Once that's done I'll take it in for the mandatory inspection before I can get it plated.
11-29-2016, 09:27 AM
#26 (permalink)
Failed inspection
With the rust repaired, the winter beater Echo is now at the mechanic's for its mandatory mechanical inspection and emissions test.
I had gone over it before taking it in - lights, tires, brakes (iffy - corrosion on the rotors), ball joints/tie rods, exhaust - and it looked passable to me.
It failed! For a mangled/deteriorated front control arm bushing. Oops! (I need to watch more closely for suspension bushings - last winter's beater Prius failed for the same reason.)
So yesterday I brought the car back home to fix it myself, but after eyeing the rusty control arm nuts & bolts I'd have to deal with, plus looking at the cold garage floor, I hopped back in and drove back to the shop: "You do it!"
My tolerance for DIY is getting pretty low with winter setting in.
Change of plans: it's going on the block sooner than later
With this month's unplanned fleet addition of Canada's cheapest, 50 mpg* Miata, I've decided to put the Echo up for sale as soon as it's licenced.
Too many vehicles! There's no more room at the inn. And I don't like to litter the manger with vehicles.
We'll see what happens.
11-29-2016, 02:52 PM
#27 (permalink)
...beats walking...
RE: Skeptical MPG, what does the MILAGE calibration look like? Known?
11-29-2016, 04:00 PM
#28 (permalink)
Calibration is not known yet.
I haven't been driving the car since I picked it up in April and used it for a week and a half on the temporary permit.
But depending on whether it sells quickly or not, I may yet get that info.
Just heading to the shop now to pick it up and see how much I'm getting dinged for the inspections & bushing replacement.
11-29-2016, 05:00 PM
#29 (permalink)
...beats walking...
OOPS, let me rephrase my question: Correct size tires installed? If not, they could account for the optimistically high MPG number.
11-29-2016, 06:14 PM
#30 (permalink)
Ah. Yes, tires are stock size.
