10-21-2014, 03:26 PM
#21 (permalink)
Hypermiler
Same slight fuel usage reported on my 2009 Fit.
I contacted Scangauge about it, suggesting a simple "if rpm = 0, gph = 0, else ....." code change. They replied that it's not a big error so no plan to fix it. This was about a year ago. I hope you have more leverage with them.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
10-22-2014, 11:28 AM
#22 (permalink)
I may not be good for much, but...
I'll have our engineer take a look and see if we can make any changes to help with this. Without causing any other issues of course.
I also provided a list of affected vehicles from this thread, and offered to be a guinea pig/tester if needed. (I suggested others here might be willing as well.)
2006 Toyota Corolla
1999 Saturn SW2
2003 Toyota Matrix
2001 Toyota Avalon
2005 Scion xA
2009 Pontiac Vibe
2002 Toyota Camry
2013 Subaru WRX STi
2007 Honda Civic
2009 Honda Fit
10-22-2014, 03:18 PM
#23 (permalink)
Also...
This reveals a lack of understanding of the customer.
(Or at least one of their customer profiles.)
10-22-2014, 10:01 PM
#24 (permalink)
Liberty Lover
'99 civic vs eoFc
After a trip using eoFc, a fillup consisted of significantly more gas than expected, the only time this has happened. The pump was tested and reported to be accurate.
I suspected that the car was using gas based on RPMs when the ignition was off, and have not used eoFc since that time. However, my use of eoNc has been accurate and has been verified at the pump.
10-24-2014, 08:52 PM
#25 (permalink)
A fix is in the works... and in the mail
Originally Posted by Linear Logic
We've got a preliminary version for you to try out.
Good news: an updated Scangauge is on its way for me to test in the Civic.
10-24-2014, 11:24 PM
#26 (permalink)
...beats walking...
*IF* the updated software (revision) is successful, will LINEAR LOGIC let the rest of us send in our units for upgrade (at a reasonable cost)?
10-25-2014, 07:44 AM
#27 (permalink)
In the past, I think the charge was $15?
10-28-2014, 03:33 PM
#28 (permalink)
fixed
I'm not sure what the charge is for flashing the latest version. I'll ask.
But it appears to be fixed!
Before (my ScanGauge):
Above, that's my ScanGauge. The car is moving and the engine's off (should have switched to MPH from VLT).
After (test ScanGauge from Linear Logic):
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
10-28-2014, 04:28 PM
#29 (permalink)
So, can we send in our units, and get this? Soon, I hope?
10-28-2014, 04:49 PM
#30 (permalink)
Not bad for a machine
Is that 4.13EM as in EcoModder?
